Turn Signal Parking Light Swap
Old Feb 13, 2021 | 11:09 AM
87NC4RUNNER's Avatar
Does anyone know an easy fix for the fast blinking that takes place when you swap the turn signal and parking lamp locations? I mounted my ARB and swapped the turn signal from the bumper to the corner lights but they blink fast like a bulb is out. Thought maybe a fuse could be swapped or something knowing one is a lower voltage and most likely causing the issue. Any help is appreciated.
Old Feb 13, 2021 | 02:39 PM
Blueman's Avatar
Maybe switch your flasher relay out for an electronic version that's not load-dependent?
Old Feb 14, 2021 | 09:02 AM
muddpigg's Avatar
The older flasher relay has a resister that when cut out will flasher normal with lower resistance bulbs.
Some of our trucks came with them some had newer version that lack resistor. But older version is plug and play with our trucks. Google should return part numbers and tutorials on how to do mod.
Old Feb 21, 2021 | 10:13 PM
RAD4Runner's Avatar
This^^^
But
perhaps you meant, higher resistance = lower current draw = lower power lights which LED lights are
lmutter
Feb 1, 2016 10:30 PM
reallifedog
Nov 11, 2014 02:35 PM
SR5
Sep 25, 2008 12:48 PM
HUTCHSTACO
Jan 7, 2006 11:45 AM
Churnd
Mar 24, 2003 09:37 AM
