turn signal burnout
Old Mar 24, 2003 | 07:38 AM
Churnd's Avatar
turn signal burnout
One of my turn signals has burnt out. I took it off to see if it was a bad connection, but I wasn't that lucky. I also couldn't see anywhere to could replace the bulb, so I guess I gotta order a new enclosure with the light in it? If that's true, how much are these things?
EDIT:
Sorry, guys... I had a brain fart. It's the drivers side front turn signal.
Old Mar 24, 2003 | 07:45 AM
jx94148's Avatar
You can get to the bulb with a phillips screwdriver. In the rear you undo 6 screws to remove the taillight assembly and then remove the lenses from that, the bulbs can be changed from there. Up front its 2 screws that remove the whole light, the lens will probably fall off and you can then change the bulb.
Old Mar 24, 2003 | 07:50 AM
Corey's Avatar
Co-Founder/Administrator
Churnd, your turn signals are just like mine, the long yellow ones on the front bumper.
I finally had one burn out for the first time a few months back.
I could tell as when I put the blinker of for the left, it flashed real fast inside on the dash, but not outside.
Just pull off the cover with the two screws, and the bulb twists out of a plastic encasing.
Freshly scanned on my PC.
http://www.pnw4runners.net/tech/91_bulbs.jpg
PS, I was not sure if you meant front or rear since you did not state.
Old Mar 24, 2003 | 09:37 AM
Churnd's Avatar
Thanks for the help guys! Corey, thanks for the scan... that helps alot. I'm about to run to the parts store and get a bulb.
ghostmoney
Jan 28, 2018 11:42 AM
Shoua
13
May 22, 2016 05:19 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
PopsDad1
Jul 30, 2015 02:21 PM
