Tune up info needed
Tune up info needed
My runner will be needing a tune up soon and it will be my first for this vehicle. I am planning on replacing the following:
-plugs
-wires
-dist cap & rotor
-fuel & air filter
-O2 sensor
I've read here where Denso & NGK are preferred for plugs(is either better or about same?) and OEM for fuel filters, but what about the plug wires, dist, and O2 sensor?
Thanks in advance.
-plugs
-wires
-dist cap & rotor
-fuel & air filter
-O2 sensor
Thanks in advance.
NGK for sparkplugs.....and OEM for O2 sensor (kind of expensive...but the previous owner of my truck put an aftermarket one in my truck and it never ran right till I put a new OEM one on there.....) And everything else...i dont know.
We have vendors on belonging to yotatech (strap). You can get great deals on OEM stuff from them.
The fuel filter is a PITA on the 3.0 (IMO). I'm not ever doing it again lol.
Use OEM plug wires.
I used Denso plugs.
Use OEM plug wires.
I used Denso plugs.
Originally Posted by Elton
i had a 91 4runner and the fuel filter was on the frame rail its not that hard
Originally Posted by gohawks
I noticed ZERO improvement in any fashion (mpg, driveability, acceleration, etc) on an original fuel filter with 200,000 miles.
Not to say that this isn't necessary to keep everything running properly, it's just over rated in my opinion.
I have used Bosch Platinum plugs in my truck since it was new and have nothing but good things to say about them.
I have also used NAPA for the cap and rotor. When I got the truck no one else in town had a cap for it but NAPA so I got it from them. It worked fine so I continued to get my tune up stuff from them.
My experience with the fuel filter mimicks those above me. I've never felt a difference. I just try to make sure it gets changed every 100k or so.
Thanks 8422 - I almost forgot it - it's now on the list. Once again, is there a brand preference for PCVs? OEM? I know it's a pain to get to on this engine and I only want to have to do it once.
I had heard from someone else as well that toyota fuel filters last a long time and don't need changed often. I'm thinking of changing it because the truck is new to me and it does have 150k - at least then I know it's good.
Jun 1, 2021 01:51 PM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
Jul 6, 2015 09:01 AM
