Tips on more mpg?\tick
Old Jul 9, 2013 | 11:38 AM
bbrideau's Avatar
its sad, my wifes 3vz gets better mileage than my 22re =[
Old Jul 9, 2013 | 12:54 PM
Hilux4Life's Avatar
So far there are good suggestions on this thread. I would also mention alot of it depends upon on how you drive it. I usually get around 22-23mpg, but I also drive my 22re like a grandma and coast downhill whenever possible. I try to keep the RPM's down as much as possible.
Old Jul 9, 2013 | 03:04 PM
z31freakify's Avatar
I have heard of those HHO (run your car on water systems) and for what ive seen there are some good results from people out there, will I put it on my truck? Maybe. prices are cheap so why not.
But I rather you be our guinnea pig and let us know if it works there like $60
Old Jul 9, 2013 | 03:32 PM
snobdds's Avatar
With old metal bed ~ gas mileage was around 22 mixed.
With new fiberglass bed ~ mileage went to 25 mixed.
Moral of the story...weight kills gas mileage.
Ditch all the extra weight if mpg is your main factor.
Old Jul 10, 2013 | 09:55 PM
  #25
Ven0m's Avatar
Originally Posted by highonpottery
18.5mpg is pretty good for a 4wd brick with only 90hp to push it around. like others have said, start at the engine and make sure she's running in tip top shape - so do a full tuneup even though your rig is only a baby with little over 100k on it, it's 24yrs old and sat for a good amount of that time with so little mileage.
i believe mythbusters proved the tailgate-down theory to be defunct and you actually get better mpgs with it up, since it creates a bubble of air = less drag. less weight overall in the rig will improve mpgs for all vehicles. make sure tires are not under-inflated. make sure wheel bearings are packed with non-24yr old grease and with the correct amount of preload on them. check to make sure all your diff trans and tcase fluids are in spec and not the original fluids. back off of the skinny pedal every now and then. coast as much as possible especially when coming up to red lights. driving like an old man vs driving like you stole it will significantly increase mpgs. run some injector cleaner or seafoam the engine, clean out your intake plenum from all the carbon/oil deposits. if you can afford it, do a CAT-back system for increased flow. make sure your stock paper air filter is fresh - it filters better than aftermarket and if not dirty flows decent too. wash your rig every now and then
all those little things you can do will help get you better MPGs even though you're pretty good as-is. my truck gets around the same as you for hwy driving, but i like to use lots of skinny pedal and my truck is a few inches taller/more wind resistance. good luck!
haha thanks once i got it from my grandpa at 90k miles after the 90k service i made sure to check all that i contesntly check for clean air filters clean parts,clean oil and trans fluid etc etc. even though i may be a 16 year old driver it may be hard to believe that i don't beat it to hard, to be honest people tell me i drive like a grandpa haha. and for cleaning i wash every week and claybar and wax every month for the extra airflow and power! and i rolled on the bed liner myself and ditched the plastic one;P and whenever i can ill throw the toneu cover on from when the truck was given to me . thanks again for everything im getting very good information and if i already knew it you guys are really clarifying it for me! im so glad i joined this fourm
Old Jul 10, 2013 | 11:52 PM
  #26
nuttynu's Avatar
my 93 v6 gotton around 23mpg, i just threw in the new K&n and new plugs, and will evaluate the what my new mpg is .
JonG85
Jan 18, 2023 04:31 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
