testing compression
Old Nov 11, 2005 | 09:01 AM
Jared Ajlouny's Avatar
testing compression
my runner is leaking oil (not to the point where it gets on the ground, but it makes the engine look messy). all i want to do is test the compression cause if the compression is good im just going to replace the head gasket and oil pan gasket and call it a day..... i know on my jet ski to test it you take both plugs out (2 cylinder) and put the guage in one and hold the throttle open and start cranking away..... is that what i do for the runner?! i know 2 stroke engines like the back of my hand, but i have never delt with a 4 stroke........
Old Nov 11, 2005 | 09:09 AM
surf4runner's Avatar
if doing all cylinders, i recommend removing all plugs first. otherwise no diff betweeen doing it on a 2 or 4 stroke.
Old Nov 11, 2005 | 01:59 PM
MTL_4runner's Avatar
Pull the EFI fuse when doing it so the vehicle does not start.
Old Nov 11, 2005 | 09:29 PM
i dont think it will start without spark plugs....
Old Nov 11, 2005 | 09:55 PM
marko3xl3's Avatar
You never know...better safe than sorry!
Old Nov 12, 2005 | 06:29 AM
Just pulling the plugs will not stop the ignition from firing and you may fry the ignition (maybe not, but I wouldn't chance it).
Old Nov 12, 2005 | 08:10 AM
YotaJunky's Avatar
How about just pulling the wire from the ignition coil for those that use a coil, cap rotor etc..?
Troy
Old Nov 12, 2005 | 11:55 AM
DudeBud's Avatar
Troy
much easyer to pull the efi fuse so the injectors don't squirt fuel. thats just what i do
Old Nov 13, 2005 | 05:41 AM
YotaJunky's Avatar
Here's a good article. I think I'll test mine out now.
http://www.geocities.com/SiliconValley/2072/carcomp.htm
Troy
Old Nov 13, 2005 | 05:58 AM
waskillywabbit's Avatar
Probably might be a good idea to do a compression test and a leakdown...mine leaked oil, smoked like a fat indian chief and in general ran crapy...compression test was all fine...leakdown wasn't so great, but okay...but I just rebuilt the whole engine anyway...all new OEM parts and it runs like a new squirrel again.
eggens
Oct 27, 2015 03:14 PM
_Nicco_
Sep 21, 2015 03:06 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
Boomer8404
Sep 10, 2015 09:01 AM
