Temp sensor gauge or sender?
Old Apr 17, 2019 | 04:48 AM
coastal's Avatar
Hello all. First time poster, long time creeper. I have an 87 22re 4runner. I've only driven it 100 miles since it broke down on me and left me in shame of my bad purchase, so this will be my first post of many I'm certain. But first issue I want to address, is how to address OBD Code 4. The temp sensor aft of the coolant hose to the intake has a shotty cable, and since removing it I can see it's in bad shape, so I know this needs to be addressed whether it solves the CEL. I assume it's the temp sensor for the gauge, but I've read people say it's for the AC cutoff. The one I have does not look like photos, perhaps it's even the wrong sensor. I know embarrassingly little about this trucks history. But can anybody confirm what sensor this is, whether cooling sensor, gauge sensor, or even possibly AC cutoff? And have they ever seen one look like this?
Thanks in advance. On a side note, the truck shut off when taken out of 5th on the highway. Supposedly heads were reworked 500 miles ago, along with new water pump and timing chaing, and distributor in last 50. Since then it's started back up 2 out of many cranks and sounds like something is clanging. She'll turn over sluggishly and I can manually turn the crank. Fuel pump works. Researching all I can do and check prior removing valve cover and main block parts and replacing parts that would not be included in long block. Replacing fuel filter and testing compression this week.
Old Apr 17, 2019 | 07:29 AM
Co_94_PU's Avatar
This is not the AC cutoff, you can tell by the round housing and because the wire is coming out if the engine harness.
The AC cut off comes out of the body harness and has an exposed spade connector.
The temp guage sensor is actually located farther back on the intake. Shine a flashlight down beside the cold start injector and you'll see it near the head side.
The sensors for the ECU are located below the radiator inlet hose and face the front of the vehicle.
Old Apr 17, 2019 | 08:11 AM
coastal's Avatar
Appreciate the reply, that helps to understand what it isn't. From the circle on the engine photo, can you tell me what it is?
Old May 1, 2019 | 07:57 PM
Samson3113's Avatar
Maybe this will help
89428-28030
Switch, Temperature Detect
https://www.megazip.net/zapchasti-dl...ystem-17850685
Jim
Old May 2, 2019 | 12:37 AM
ev13wt's Avatar
5 Year Member
Uhm, isn't that indeed the temp control for the ac?
Old May 2, 2019 | 04:12 AM
coastal's Avatar
89428-28030
Jim
Thanks Jim! Now that I see it with the part number in a diagram, which by the way is a great reference, I can find it online. Which btw, appears to be called a Coolant Temp Sensor when I search for that part number. It's only ~$17 on Amazon, supposedly being a Toyota part. Wonder why such the price difference?
Old May 2, 2019 | 10:22 AM
Co_94_PU's Avatar
AC cut off on the left, has an exposed male terminal, it's wire comes from the harness on the fender.
TSW on the right, has a round plastic housing around its terminal, it's wire is part of the engine harness. (This is the one pictured above)
Old May 2, 2019 | 04:02 PM
Samson3113's Avatar
Part: 89428-28030: SWITCH, WATER TEMPERATURE on Thermostat Housing
Mine is for a 1986 SR5 4wd EFI, so remember they will be different
Those ones on Amazon may not have right connector
I had to go to Toyota
Jim
Old May 2, 2019 | 07:41 PM
RAD4Runner's Avatar
Originally Posted by coastal
coolant thermo switch (ecu-tsw)
Needs ground through bare, shiny metal of mounting threads. I refurbished mine: https://www.yotatech.com/forums/f199...l#post52391719
TacoWeez
Apr 17, 2019 03:09 PM
