telescoping cv axle
#62
thanks again PHILLY you came to the rescue.lol well after CORAX.. but yeah since there pricey ill just replace the outer with the one i have and call it good. Thats quite a bit for a damn cv axle. Glad i didnt pay that much for it. Im finding that the p.o did a lot of after market work. I know alot about the truck its just i dont look into things until they break then have to find out what parts the po used. Im glad he had a big wallet.
#67
There not custom After All. http://www.downeyoff-road.com/Chassi...riveTrain.html
scroll down there called long travel slip yokes.
Its a neat idea and design though.
#69
Im sorry Matt but i dont totally agree with you on that. If you look you have crawlers all the time switch there cv axles out for u-joints. They say its stronger and such. Im new to this thats why i brought this up. Here is a example of what im talking about. (even though it pertains to a jeep) http://www.ironrockoffroad.com/Merch..._Code=IR-WFAAC
I Have no clue as to which one is better but i have one of the (custom) axles on passenger side and have never broken it. I went threw three on the drivers side. When i bought the truck the drivers side axle was already broke, so thats why i replaced it the first time with the oem part.
#71
No for sure, use what you like, if it does vibrate at the speeds you're going, why not? Just know that IF the outer CV has been upgraded to something as strong as a U joint (they look stock though), then you run the rick of blowing up your front diff. You have 33" tires, to you could be out $200 for a new used 4.88.
#74
well i would take a pic for you but the one that is out is binded together. As in its not slipping out..lol i had it out now for over a year so i will have to pry it apart. but my shop is 30 something degrees right now. So maybe tomorrow i will try sorry bro
#75
#79
just make sure that before you reinstall them you have the slip yoke sliding smoothly - make and index mark so they line back up the same way on re-assembly, take it apart, clean out the old grease, clean the splines with steel wool, lube with high pressure marine grade grease and reassemble - if the slip yoke is binding it will cause a side load on the outter CV which could lead to premature wear / failure
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
downey makes them...
