telescoping cv axle
Old Dec 8, 2008 | 05:18 PM
  #61
akaphilly's Avatar
the catalog has some really cool stuff in it. lots of info.
i wrote the price next to them. pretty expensive!
Old Dec 8, 2008 | 05:23 PM
  #62
sincal's Avatar
thanks again PHILLY you came to the rescue.lol well after CORAX.. but yeah since there pricey ill just replace the outer with the one i have and call it good. Thats quite a bit for a damn cv axle. Glad i didnt pay that much for it. Im finding that the p.o did a lot of after market work. I know alot about the truck its just i dont look into things until they break then have to find out what parts the po used. Im glad he had a big wallet.
Old Dec 8, 2008 | 05:26 PM
  #63
akaphilly's Avatar
yea glad i could help. post a pic of your idler arm sometime i remember seeing a peice of it and thought i saw a shield. just curious. i like seein new stuff.. cool truck!
Old Dec 8, 2008 | 05:45 PM
  #64
sincal's Avatar
I just replaced that today so here ya go i still have to swap it onto new one. so heres some pics with it off and idler arm still attached
Old Dec 8, 2008 | 05:56 PM
  #65
akaphilly's Avatar
damn that things pretty cool
Old Dec 8, 2008 | 06:00 PM
  #66
sincal's Avatar
lol..just a little armor. Has saved my idler arm quit a bit too
Old Dec 8, 2008 | 06:03 PM
  #67
DeathCougar's Avatar
Originally Posted by sincal
There not custom After All. http://www.downeyoff-road.com/Chassi...riveTrain.html
scroll down there called long travel slip yokes.
So it is still custom, since this kit is designed for the driveline, and adapted for your CV. Its still custom anyways, since you have to weld it into your driveline or CV. No one makes the axles and sells them that way.
Its a neat idea and design though.
Old Dec 8, 2008 | 06:06 PM
  #68
sincal's Avatar
Death cougar did you look at the pics that PHILLY posted. Downey sells them as is
Old Dec 8, 2008 | 06:21 PM
  #69
Matt16's Avatar
Im sorry Matt but i dont totally agree with you on that. If you look you have crawlers all the time switch there cv axles out for u-joints. They say its stronger and such. Im new to this thats why i brought this up. Here is a example of what im talking about. (even though it pertains to a jeep) http://www.ironrockoffroad.com/Merch..._Code=IR-WFAAC
I Have no clue as to which one is better but i have one of the (custom) axles on passenger side and have never broken it. I went threw three on the drivers side. When i bought the truck the drivers side axle was already broke, so thats why i replaced it the first time with the oem part.
As I said, you've got the stock outer CV, which is the weak link, so beefing up the strongest portion of the shaft does you no good really. I haven't ever heard of a IFS rock crawler. You really don't have to agree with me on this, or evolution for that matter, it's just a fact that U joints act as described. Every used a wobble socket wrench extension, the effect is quit pronounced. Whether it is noticeable to the driver depends on the angle.
Old Dec 8, 2008 | 06:26 PM
  #70
sincal's Avatar
like i said before. I didnt pay the $570 for them but since i have them i might as well use them right
Old Dec 8, 2008 | 06:31 PM
  #71
Matt16's Avatar
No for sure, use what you like, if it does vibrate at the speeds you're going, why not? Just know that IF the outer CV has been upgraded to something as strong as a U joint (they look stock though), then you run the rick of blowing up your front diff. You have 33" tires, to you could be out $200 for a new used 4.88.
Old Dec 8, 2008 | 06:37 PM
  #72
sincal's Avatar
the outer ones that are on the downey are downey outers with a longer shaft. Tougher i dont know but i will see i guess thanks for the input
Old Dec 8, 2008 | 06:45 PM
  #73
allnmstkn313's Avatar
I don't strength was really the issue, but rather eliminating binding was...
Anyways, I would still like to see some closer pictures of the slip yoke itself
Old Dec 8, 2008 | 06:54 PM
  #74
sincal's Avatar
well i would take a pic for you but the one that is out is binded together. As in its not slipping out..lol i had it out now for over a year so i will have to pry it apart. but my shop is 30 something degrees right now. So maybe tomorrow i will try sorry bro
Old Dec 8, 2008 | 09:11 PM
  #75
Downey makes the things huh? Interesting
Old Dec 8, 2008 | 09:43 PM
  #76
space-junk's Avatar
you really need to read DC... downey makes them...
Old Dec 8, 2008 | 09:46 PM
  #77
thats what I meant to say. Long irritating day.
Old Dec 8, 2008 | 10:14 PM
  #78
space-junk's Avatar
well, at least in the smilie, your smiling while chopping me with the chainsaw...
Old Dec 9, 2008 | 05:42 AM
  #79
corax's Avatar
just make sure that before you reinstall them you have the slip yoke sliding smoothly - make and index mark so they line back up the same way on re-assembly, take it apart, clean out the old grease, clean the splines with steel wool, lube with high pressure marine grade grease and reassemble - if the slip yoke is binding it will cause a side load on the outter CV which could lead to premature wear / failure
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
