straight six swap?? pros//cons?
#42
Originally Posted by indica4r
so hows the 4wd on the supra motor work? does the 22re tranny bolt up? or does it bolt to a FJ tranny?
I don't know about the 2jz engines. Haven't really looked into their tranny options too much. I believe some of the 2jzge engines use the W58 tranny, so the w56 may work, but I dunno.
The 2jzgte uses a V160 manual and I don't think there is a way to hook a transfer case to that unless you go with a divorced.
Just my $.02.
#43
Jack, you can set up your user CP to send you emails whenever you get 1 or more replies to a thread you posted in. Heres what you do to activate the email notification:
1. Click on "user cp" on the upper left of the screen.
2. Click on "edit options".
3. Look down where it says "default thread subscription mode"
4. Click the down arrow on the drop down menu and select "instand email notification"
5. Click "save changes" at the very bottom of the page.
You will now get an email when a message has been replied too. You can also select some of the other options there like getting an email when your recieve a PM (private message--if activated.)
The tranny you have is a R150 and I don't know if that will bolt to any of the diesels. I doubt it. I honestly don't know much about the diesel swaps as I haven't looked into it much. I'm sure somebody esle will chip in.
The www.toyotadieselmadness.com website should have an answer for that too.
Daniel
Daniel
