Stock cams with a bored over 3vz?
Old Dec 7, 2009 | 07:21 PM
Tubbyfatty's Avatar
My truck blew its HG last night and one of my buddys has a 3vze block and pistons that are bored 50 over. Im going to do a full rebuild on either block, stock or bored block.
So i was wondering. Can I use the stock cams for this or do I have to get some better cams?
Old Dec 7, 2009 | 08:55 PM
Tubbyfatty's Avatar
anyone?
Old Dec 7, 2009 | 08:57 PM
camo31_10.50's Avatar
i dont see why not???
Old Dec 7, 2009 | 10:17 PM
peow130's Avatar
You can use stock cams, but you could get more power using aftermarket ones.
Old Dec 7, 2009 | 10:23 PM
Tracey98277's Avatar
Crower Equipment Mfg. in San Diego, CA they don't list 3vze cams on their web site but you can call and have a custom regrind done for $200 i recommend the 272 degree durration. i have 264's and probably could have got more out of the 272's. they cut my base circles a little to small so i had to order all new shims from toyota for $100.
Old Dec 8, 2009 | 05:49 AM
vandert's Avatar
What he said but remember anything bored over 40 is considered iffy, you get to .50 and cylinder walls are getting thin and our hot running engines run a little hotter due to the lack of heat dissipation.
Just something to consider - if you hven't done .40 yet, why jump all the way to .50?
Old Dec 8, 2009 | 09:10 AM
Tubbyfatty's Avatar
Oh, i forgot about that, should i just use my stock block and get it bored 30 over? You think that would be the best choice?
My friend bought a complete engine that was 50 over and he never used it so he said I could use it.
Old Dec 8, 2009 | 10:21 AM
olharleyman's Avatar
run the .50 over while you rebuild your motor to .30 over that way if the .50 over blows up you have a brand new motor ready to go.
Old Dec 8, 2009 | 10:25 AM
hahaha there ya go! olharleymans got a great idea lmao..
what happened to the weasy2K cams???
Old Dec 8, 2009 | 10:51 AM
vandert's Avatar
I seem to be doing this alot lately, but ^^^ What harley man said, I would do that with the .50 over as a temp thing if it's free
Old Dec 8, 2009 | 11:02 AM
Tubbyfatty's Avatar
Thats a good idea olharleyman. I still have to rebuild both blocks but i just might do that. I will get the 50 over block and pistons for free too. I just need to pay for all the new parts, bearings, machine shop work etc...
DOA racing has cams for the 3vz, ive never heard of em before tho. i dont know what happened to weasy2k.
Old Dec 8, 2009 | 12:49 PM
weasy2k disappeared, he stopped getting online and his website dissappeared too. don't know what happened to him.
Old Dec 8, 2009 | 12:58 PM
lonecountryboy's Avatar
Remember 50 over on this is in mm not inches so 50 over when it is stamped on the piston is really .20 over in inches.
Old Dec 8, 2009 | 12:59 PM
i wouldn't mind having a set of cams to wake up the 3vz..how much were yours Tracey????
i dont want a CRAZY camshaft..but a mild one would be nice..something i can DEFINITELY feel though lol..
maybe give it a small Lope at idle..barely noticeable..but definitely there lol
Old Dec 8, 2009 | 02:57 PM
Tubbyfatty's Avatar
hmmm.....on top of the pistons it says, .050
Old Dec 8, 2009 | 04:05 PM
if you went .20 over....you wouldnt have much material left...im assuming you mean .020 lmao
Old Dec 8, 2009 | 07:48 PM
camo, i got mine from crower for $200. regrinds always make the base circle smaller tho so you need new shims from toyota which is $100. i have 264's and wish i would have gotten 272's. i notice the powerband kick up at 3k rpm more than it used to.
Old Jan 19, 2010 | 05:17 PM
senior2010's Avatar
Tracey,
Hey whenever you get the cams redone to 272 or even 264 do you have to get the heads done too? i called Delta cams and the guy told me that i had to getthe heads done if i got the cams regrinded to 260 degree duration...
RatOmeter
Oct 22, 2015 03:17 PM
Iceman4193
Aug 28, 2015 08:43 PM
nonstop
7
Aug 11, 2015 09:26 AM
Fakayayou
Aug 9, 2015 12:47 AM
