Steering Stabilizer question
Old Aug 1, 2005 | 10:58 PM
fo_runner's Avatar
Hey all, I just purchased a new Rancho single stabilizer kit for my 93' 4runner. I've done some searching on the forums on how to remove the OEM "Bicycle pump", but i need some more info on how to remove it without industrial tools, just simple hand tools.
I've heard of heating the stabilizer stud on the tie-rod, and hitting it with a BFH.
Any alternatives?
Old Aug 1, 2005 | 11:03 PM
ChickenLover's Avatar
A cheapo tie rod puller from harbor freight will make quick work of that thing. It's actually pretty difficult to get a good angle to hit it with a BFH. I didn't have the HF tie rod puller when I did mine, so I ended up torching it off, then torching the stud out of the hole. Based on my experience with the bicycle pump, I doubt you'll get it off with a hammer.
Old Aug 2, 2005 | 05:17 AM
shiftless89's Avatar
Autozone sells a "pickle fork" ball joint/tie rod seperator for $10.00. I have used mine for all kinds of chores. well worth the $$ and yes it will pop off the bicycle pump too!
Old Aug 2, 2005 | 06:23 AM
AgRunner06's Avatar
Or you can go rent one for free. All you need is that pickle fork and a BFH. You might want some PB Blaster too.
I did mine in about 45 mins and that was with taking pics.
Old Aug 2, 2005 | 07:10 AM
fo_runner's Avatar
Thanks guys. Whats the change in ride and handling when I change to the Rancho stabilizer; other than the stock bicycle pump? I hear it's a really big difference.
Old Aug 2, 2005 | 07:21 AM
4Crawler's Avatar
If the stock stabilizer is still functional (i.e. the oil has not leaked out), you'll probably find little difference unless you are running wide wheels/tires or the tires are not well balanced or out of round. I have some removal tips on my web page: http://www.4crawler.com/4x4/CheapTri...ringStabilizer
Old Aug 2, 2005 | 07:40 AM
callmej75's Avatar
I just put on a new OME stabilizer and it handles better. I had no pickle fork and no transportation to get a rental so I took a pair of big channel locks and put it behind the spot where it mounted to and squeezed them while I beat the channel locks with a big hammer. It took about 10 minutes to get it off versus a pickle fork with maybe just 1 minute of work. I'd say get the rental or maybe just buy one and it will come in handy later on.
Old Aug 2, 2005 | 07:43 AM
geneius's Avatar
Exactly what he said.
Old Aug 2, 2005 | 11:15 AM
Not sure about the rancho stabilizer, but my procomp stabilizer is at least 10 times stiffer than the bike pump. I had some shaking up front before the switch. Afterwards, all was well.
Old Aug 2, 2005 | 11:19 AM
Robinhood150's Avatar
I use both stabilizers. Never bothered removing the old one.
Old Aug 2, 2005 | 11:34 AM
fo_runner's Avatar
My old bicycle pump is starting to leak quite a bit, and maybe when i pull it out, it wil start to bleed
Also, my alignment is messed; I should get the stabilizer changed before I get the alignment done.
Old Aug 2, 2005 | 07:38 PM
fo_runner's Avatar
One reason I don't like non-off-road mechanics
Okay, I brought my Rancho Steering Stabilizer to an auto-garage, so I can let them install it for me. I was too lazy and I didn't have the time to install it myslef. Anyways, I brought the part along with the brackets to the mechanic, he took the stabilizer, and put up against the old one. And to my amazement, he said the stabilizer won't bolt in, and the mounting holes are all wrong, DUHH! Thats why I brought the brackets to mount it too! I told him that the passenger side bracket goes on to the idler arm, geuss what, he says there is no way it can go on the idler arm unless you weld it to the frame
Then, like most auto-shops do, they you make order OEM parts, when a part is worn out. But, I didn't want a OEM part. So then he calls the local stealership, and they're asking for $271 CDN for an OEM BICYCLE PUMP! So then I took all my parts and left the shop immeadiatly
Old Aug 2, 2005 | 07:48 PM
4Crawler's Avatar
Some install write-ups on the pge below:
http://www.off-road.com/toyota/tech/suspension.html
I think OME makes one of the only true bolt-on stabilizers, many of the others need their own brkts. (like Rancho), I know the Rancho and Heckethorne stabilizers I've used on my '85 required additional brkts.
Old Aug 2, 2005 | 08:20 PM
mtnfreak's Avatar
I purchased a stabilizer from JC Whitney - bolted right up, no brackets, no welding. Works fine for a DD and light to moderate off-roading. Getting the old one off was a PITA! Had to use the pickle fork, BFH and blue wrench, even after daily applications of PB for nearly a week beforehand. Gotta love Colorado salt & MagChlor!
Old Aug 2, 2005 | 09:23 PM
fo_runner's Avatar
I noe this sounds dumb, and out of hand coming from an exp. mechanic, but what does a leaky or bleeding steering damper mean, and what causes it?
I know its a bad thing
Old Aug 2, 2005 | 09:25 PM
4Crawler's Avatar
It means the shock seals have worn out and the hydraulic oil inside is leaking out. Once enough oil is gone, the shock no longer works (as in damping motion).
Old Aug 2, 2005 | 10:17 PM
deathrunner's Avatar
Ibought a procomp one from 4wheel parts a while back. I don't remember having any issues with removal and I didn't need any brackets to mount it.
Old Aug 3, 2005 | 06:32 AM
geneius's Avatar
Yup, the procomp ES2000 is a perfect fit.
glowz825
Jan 25, 2022 09:28 AM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
bobpat
Aug 1, 2015 09:25 PM
