Starter problems
Old Jun 6, 2011 | 08:00 AM
love2boutdoors's Avatar
Starter problems
Put a new starter on a 89' 4wd and it worked great. When I put it on I noticed the battery hold down was missing the threaded rod and moved freeely. My son drove it in the pasture, hit a bump, and the hold down hit the positve terminal on the battery. Now it won't crank, can hear starter turning but nada. Took starter off and tested and its good. Thinking he may have "welded" battery plates together but don't know. Any ideas?
Thanks
Old Jun 6, 2011 | 10:25 AM
All fuses look good, trying to see if battery will take a charge now.
Old Jun 6, 2011 | 02:29 PM
Junkers88's Avatar
When you say you hear the starter turning but it won't crank do you mean the starter is turning but not engaging the fly wheel or the starter is engaging the fly wheel, the engine is turning but won't fire up?
Old Jun 6, 2011 | 04:12 PM
The starter is spinning but not making contact with the flywheel. Push starts fine.
Old Jun 7, 2011 | 04:34 PM
swampfox's Avatar
Did the stater drive move forward when you tested the starter? If it doesn't move when the starter spins it isn't engaging the flywheel.
Old Jun 7, 2011 | 11:52 PM
darkmourning's Avatar
i see a new starter in your future. sounds like that weld job fried the stater.
Old Jun 8, 2011 | 04:35 AM
Got home last night and straight wired the starter from the ignition wire on the starter to pos battery and she turned over. Disconnected and tried the key and it started??? Started it 15+ times and never missed a beat. Don't know if it freed the solinoid up or chip in flywheel (none observed when took starter off) but it works.......for now.
Thanks for the replies.
Old Oct 7, 2011 | 09:02 AM
mmayabb's Avatar
When I start my 94 pick up it screams and then goes away. I thought it was the water pump, but replaced that and it stills does it. My friend told me that it could be the starter solenoid...is that the problem?
Old Oct 7, 2011 | 09:47 AM
TNRabbit's Avatar
You should start your own thread....
I'm guessing it's one of your timing belt (3vze?) pulleys going bad.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
