Second Blown HG on 3VZE: Desperate
Old Feb 17, 2009 | 10:06 AM
  #121
Jay351's Avatar
So you gonna throw a 1uzfe in there or what?
Old Feb 17, 2009 | 11:26 AM
  #122
TNRabbit's Avatar
I wish....judging from some of the attempts/threads I've seen. that would be an INCREDIBLY complex conversion....
Old Feb 17, 2009 | 01:53 PM
  #123
Jay351's Avatar
Not really that bad.
You can buy motor mounts, bellhousing and all the wiring info is out there. I really think the biggest hurtle is the cost.
Its would be great though, all the power you need, same mpg (or better in most guys cases) and a nice reliable all aluminum motor.
Old Feb 17, 2009 | 02:16 PM
  #124
TNRabbit's Avatar
I don't know; I've read a lot about issues with oil pan clearance/custom pans, headers (OEM manifolds don't fit), and matching up transmissions.
Old Feb 17, 2009 | 03:47 PM
  #125
bigtrucknwheels's Avatar
hmm.
for me, I am going the 7M route, but then again, my truck is now offically a project truck, and cost isn't really a factor in that decision.
I STILL say, even now that I own a 5VZ, that there is no way that swap is ever worth the money it costs...
Old Feb 17, 2009 | 03:57 PM
  #126
Jay351's Avatar
Well from what I have read, a 2-3" body lift allows the engine to sit up high enough to clear the oil pan, and the stock manifolds.
A little tranny tunny pounding is in order...
I spend a lot of time over on www.lextreme.com Lotsa guys on there have done the swap!
The big issues would be:
Cost for the r150f/1uz bellhousing adapter and a flywheel
Cost of cooling system (bigger the rad and fan the better!)
possible driveline lengthening/shortining needed
Old Feb 18, 2009 | 07:54 PM
  #127
302Toyota's Avatar
when i popped my 2nd set of hg i use OEM head hg because toyota updated them and changed a few things i resurfaced it yet again and put new head bolts in and i havnt had a single prob yet knock on wood use factory gaskets on this one
Old Feb 19, 2009 | 04:35 AM
  #128
mt_goat's Avatar
You might want to rethink that statement. A body lift (by itself) doesn't raise the engine. Just admit it... that is a hard swap compared to the 3.4.
Old Feb 19, 2009 | 06:22 AM
  #129
mt_goat's Avatar
There hasn't been enough talk about the resurfacing step IMHO. One guy the other day mentioned that a machine shop had wrongly resurfaced his head using an abrasive meant for a cast iron head. Aluminum is much softer than cast iron and is harder to get smooth with abrasives.
Old Feb 19, 2009 | 07:50 AM
  #130
runethechamp's Avatar
My machine shop guy said that the heads were supposed to be resurfaced in a particular way because of the aluminum. Wonder if he compared it to basically cutting off very thin slices of the metal... If there is interest I can call up there again and see if I can get a confirmation on that.
Old Feb 19, 2009 | 07:53 AM
  #131
mt_goat's Avatar
I'm interested, my 5VZ has aluminum heads too.
I remember one guy posted up pics of his heads after resurfacing and it looked like the shop took a belt sander with 80 grit sand paper to them.
Old Apr 17, 2009 | 01:21 AM
  #132
TNRabbit's Avatar
Timing belt went on yesterday; hope to get this puppy buttoned back up today!
Old Apr 17, 2009 | 03:23 AM
  #133
Cyberman's Avatar
Good luck Rabbit.
Old Apr 17, 2009 | 04:58 AM
  #134
brunner628's Avatar
im doing the same thing to mine as well. my buddy works at toyota and got me the updated gasket set. The set name is VO-6, it was the set that they used for the recall. We'll see how it works
Old Apr 17, 2009 | 09:47 AM
  #135
Best of luck! heres to hoping this is the last time you have to do it.
Old Apr 17, 2009 | 01:47 PM
  #136
TNRabbit's Avatar
Damn; dead battery. Will have to continue after work tomorrow....
Old Apr 17, 2009 | 03:38 PM
  #137
flashkl's Avatar
agghhhhh.... I hate it when stupid stuff like that stops me from finishing a job...
Old Apr 18, 2009 | 05:42 PM
  #138
Jay351's Avatar
By That, I ment a body lift allowed you to put the engine in, sitting higher. Thus clearing the oil pan and such.
No doubt it would be a harder swap, but very worth it! If im gonna swap a motor, I want more then 30hp gain..
Old Apr 19, 2009 | 08:16 AM
  #139
thank you! I've been saying the same thing. Idk about you guys, but 3k+ for 30 HP? no thanks. 7MGTE with a few mods is about the same price, and then you're talking 200% gains. Around 300 HP, plus the sweet turbo and inline 6 sounds. Sure, you could supercharge the 3.4, but that means you easily end up with nearly 5K or more in the engine, and it still won't touch that 7M. Dump 5k into a 7M swap and you'll be a happy camper...
Old Apr 20, 2009 | 10:22 AM
  #140
So, whats the word TN?
