Second Blown HG on 3VZE: Desperate
Old Apr 27, 2009 | 06:30 AM
  #161
mt_goat's Avatar
Originally Posted by flashkl
I could do this with a thread tap before I put my heads on, right?
No...read this for a better understanding of what is being accomplished by the process:
Quoted from EB, but I think he was talking about the 22re since he mentions retorquing after a full warm up, something that would be a major PITA for a 3vze.
>>>*Other than simple overheat, the #1 cause of head gasket failure is clamping force variations.
Usually when I mention this, the answer is "I torqued it properly!"
*Yes, very likely, but torque, which is a twisting force, means almost nothing when we are talking about clamping force.
Dirt or machinery debris in the bolt holes will throw the clamping force off as much as 50% and more, even though the torque wrench reads perfectly normal.
The same happens when installing new bolts. The very best bolts made will show a rough mating surface at the threads when inspected under a microscope.
When installing new or used fastners, first be sure the bolt will spin in and out ALL THE WAY freely with simple finger pressure. Be sure they are lightly oiled, not too much which can hydraulic lock at the bottom of any blind holes and spoil your day.
Use this simple breakin procedure for any new bolts: Tighten all of them to 50%, back off 1/4 turn, then to 75%, back off 1/4 turn. Then take them to 100%, back off 1/4 turn and repeat. Do a retorque after full warmup.
*This procedure simply assures that the imperfections of the threads seat to the bolt hole threads.
Yes, time consuming, but much faster and less costly than another set of gaskets, the actual clamping force will increase vastly, even though the torque load is exactly the same.
The alternative is you may be additional twisting at the top of the bolt after the threads have come to a stop from excess friction.
If any single one does that, head gasket failure prematurely is gauranteed, plus it weakens the bolt....*EB
Old Apr 27, 2009 | 07:51 AM
  #162
bigtrucknwheels's Avatar
Originally Posted by TNRabbit
Things are getting dicey with the economy & me right now, so if it craps out, I'll probably just part the entire truck out. It would kill me to do it, but ya gotta do what ya gotta do....
I might be interested in it whole... or def. some parts off it anyways... But, it is my sincere wish that it doesn't come to this haha.
Old Apr 27, 2009 | 09:31 AM
  #163
TNRabbit's Avatar
gee....thanx.....sort of.....
Old Apr 27, 2009 | 01:01 PM
  #164
TNRabbit's Avatar
Well, I drove 140 miles round trip to work today at approx. 70 miles per hour with no hiccups~
Old Apr 27, 2009 | 01:18 PM
  #165
didn't mean it quite like that haha. I just was saying, if it comes to that point, which I hope it doesn't, I'd be very interested in taking the truck off your hands for my personal collection
and I am glad you made it to work and back just fine. your truck is much better than a Ford anyways...
Old Apr 27, 2009 | 01:30 PM
  #166
yodercrawler55's Avatar
well im very sure my headgasket is going.....AGAIN!! I got a new block (22re) and head last november since the old one was warped. I'm so pissed, any reccommendations on what brand of headgasket i should use? White smoke appeared this morning and it had symptoms for about a week but i thought it was fuel delivery problems.
Old Apr 27, 2009 | 02:09 PM
  #167
time for a 7m, though that surely won't fix your head gasket problems...
Old Apr 27, 2009 | 02:37 PM
  #168
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Dealer. Period. Sometimes it's best to just suck up the price. Better to pay the extra $$ up front, than to have to pay $$$$$ later.
Old Apr 27, 2009 | 02:39 PM
  #169
TN, glad to hear it's up and runnin!!!!! Congrats, dude
Old Apr 27, 2009 | 07:59 PM
  #170
brunner628's Avatar
i went the dealer route. my buddy is a tech at the local toyota place. see if you can get the new version if they make it for the 22re. i know they do for the 3vz, but thats due to the big recall.
Old Apr 28, 2009 | 01:30 AM
  #171
TNRabbit's Avatar
I've used both the dealer & engnbldr HGs and there is VERY little difference between them. The last one was dealer, so I'm waiting to see what happens with it. I DID drill small holes in the closed water jacket areas of the HG around the #2 cylinder since that's the one I've had blowing....maybe that will help.
Old Apr 30, 2009 | 06:39 AM
  #172
TNRabbit's Avatar
I'm getting some weird vibes; yesterday I drove the truck around town, stopping a several locations from 5-20 minutes each. When I first started it, it smoked like I had a ring broken (bluish) for about 15 minutes, then quit. Next time I started it, ZERO smoke at all. Next stop, no smoke. Next stop, smoking again for about 5 minutes. Then quit. WTF is going on?? I still think I might have a hose hooked up wrong...wish I hadn't waited so damn long to put this thing back together; I forgot where the heck everything went~
Old Apr 30, 2009 | 07:08 AM
  #173
mt_goat's Avatar
You need pics of a 3VZ?
Old Apr 30, 2009 | 08:44 AM
  #174
TNRabbit's Avatar
Sure. Got some good closeups? Putfile dropped ALL my linked photos; about 2,000 of them.
Old Apr 30, 2009 | 11:54 AM
  #175
I think I'd be very angry...
Old Apr 30, 2009 | 12:09 PM
  #176
Cyberman's Avatar
Maybe these will help (not mine).
Old Apr 30, 2009 | 02:29 PM
  #177
mt_goat's Avatar
Here's some of my old 93 3ZVE: http://rides.webshots.com/album/571596986BefRyb
Old May 3, 2009 | 10:50 PM
  #178
thook's Avatar
Forgive that I don't recall all of the events and doings since you're rebuild before this, but did the bottom end get a good chance to break in before the HG blew? More specifically, the rings?
Old May 3, 2009 | 11:54 PM
  #179
TNRabbit's Avatar
Well, Matthew; I figure 8,000 miles including a 2200 mile trip @ 70+ mph probably broke them in pretty well....
Old May 4, 2009 | 03:06 AM
  #180
TNRabbit's Avatar
Originally Posted by Cyberman
Originally Posted by mt_goat
Thanks, guys. Looks like I've got them all hooked up correctly.
