Runs rough at idle dies then won’t start
Old Jul 16, 2018 | 05:47 PM
Jeremyks's Avatar
89 3.0 pickup
pickup will run rough at idle with check engine light on then if it idles for extended time it dies. Once it dies it will turn over but won’t start. I can pull start it and it will fire right off and run fine. Maybe even for the rest of the day before it acts up again. Any suggestions?
Old Jul 16, 2018 | 07:19 PM
mholme's Avatar
Did you check for the code that's turning the CEL on? What's a "pull start"? Push start? Rolling start and pop the clutch?
Old Jul 17, 2018 | 12:22 PM
Jeremyks's Avatar
Im getting codes 14, 43, 52. Pull started by having another vehicle pull me around and I popped the clutch once it was rolling.
Old Jul 17, 2018 | 12:23 PM
Jeremyks's Avatar
Can anybody send a link that has a list of codes?
Old Jul 17, 2018 | 12:39 PM
mholme's Avatar
scope103's Avatar
Diagnosis
http://web.archive.org/web/201211190...85diagnosi.pdf
Old Jul 17, 2018 | 01:00 PM
Jeremyks's Avatar
Thanks.
Anybody think any of these codes would cause my symptoms?
Old Jul 17, 2018 | 01:17 PM
Jeremyks's Avatar
So after I pulled the codes I reset the ecu by pulling the efi fuse. Pickup started fine and ran 5 miles down the road with no issues and no CEL. Brought it back to the house and it let it run at idle. Ran fine with no CEL for 5 minutes or so till finally died and won't start back up.
Old Jul 17, 2018 | 01:38 PM
Jeremyks's Avatar
Unhooked battery cable for 10 minutes. Hooked it back up and it started right off. Shut it off and only CEL code was 43 this time.
Old Jul 17, 2018 | 02:09 PM
Jeremyks's Avatar
Started it back up and let it idle for 5-10 minutes till it died again. This time it threw code 14 and 43. Won't start.
Old Jul 18, 2018 | 02:26 PM
Jeremyks's Avatar
any ideas?
Old Jul 18, 2018 | 02:40 PM
mholme's Avatar
Did you research the codes? They are ignition and starter signal related. Start there. Here’s the full manual that you can go through diagnostics with.
https://ether3al.com/FSM/93fsm-mobile/
knobs
May 12, 2013 07:32 PM
rydholm11211
Jan 22, 2013 06:36 PM
Penticton BC
Oct 5, 2012 12:03 PM
adamsfence
Oct 4, 2010 05:20 PM
Maverick
Feb 24, 2006 03:15 PM
