Requesting advice on replacing front and rear bumpers
Old Apr 13, 2006 | 03:32 PM
Derek Zeanah's Avatar
Here's the deal: I just piced up a '94 4Runner, and am planning on driving it as long as it's drivable.
Right now I'd like to start by straightening out the front and rear bumpers. The rear was rearended, and the front was hit by a car that'd been t-boned in an intersection already. There was some suspension damage from the front hit as well, but that's been corrected.
Other than appearance, the harm here is that the driver's side front tire rubs when turning right, and the rear bumper is such that I can't get to the spare tire (which is still original, so this might not matter a whole lot).
Anyway, can you tell from the pictures if this will be as simple as ordering new bumpers and/or mounts and reattaching them (don't care about minor body damage)? My fear is that there's more to this then there appears...
Here's the front:
Attached Thumbnails Requesting advice on replacing front and rear bumpers-dscf1709.jpg   Requesting advice on replacing front and rear bumpers-dscf1710.jpg   Requesting advice on replacing front and rear bumpers-dscf1711.jpg
Old Apr 13, 2006 | 03:34 PM
AH64ID's Avatar
You wont know how bad the damage is until you take the bumpers off and resinpect.
Oddly enough the rear bumper bolts to the body not the frame....
Check E-bay, you will find cheap nonOEM replacments that will do the job.
Old Apr 13, 2006 | 03:35 PM
Tofer's Avatar
Sponsor
whats the tire rubbing on? the plastic lower part? if so take it off for the time being. it looks meaner with out it. i would replace the bumpers with aftermarket bumpers.
And the rear...
Attached Thumbnails Requesting advice on replacing front and rear bumpers-dscf1712.jpg   Requesting advice on replacing front and rear bumpers-dscf1713.jpg
Old Apr 13, 2006 | 03:37 PM
Yeah, ir's rubbing on the black lower part. My father-in-law suggested that sometimes when you take off the bumper you find it won't go back on. Is there a large risk of this, or is it a fairly straightforward job?
Old Apr 13, 2006 | 03:44 PM
Tofer's Avatar
Sponsor
the bumpers *should* go on as easy as it comes off.. its only a couple bolts holding the bumpers on. the rubbing wont cause any damage, but like i said if its bothering you, you can take the lower part off. the turn lights are on the metal bumper not the plastic part. i'll try to get a pic of what it looks like with out one.
Old Apr 13, 2006 | 05:14 PM
mendozart's Avatar
The rear is a 3 piece bumper. You probaly only need to replace the middle section. You also might need to replace the brackets, they tend to bend. You'll know once you get them off.
Old Apr 13, 2006 | 05:31 PM
AH64ID's Avatar
The trailer hitch probally saved the body from extensive damage....
Old Apr 14, 2006 | 07:47 AM
bigpest88's Avatar
YEah, the hitch did save you, a mustan rear ended my 95 at a 35-40mph, and the cars frontend was almost totaled. The only body part that survived on the car was the passenger fender... Good thing i had my ball on, because it would have been worse.(For me) My ball went in about and inch away from his radiator. (Man these are strong trucks)
Old Apr 14, 2006 | 10:40 AM
Bobakazi's Avatar
To me, the front bumper looks like it will be easy to replace. The rear? I would leave the dent like the rest of us and just raise it to where it needs to be. Check out this thread.
https://www.yotatech.com/forums/f123/who-has-dented-rear-bumper-honest-80151/
Old Apr 14, 2006 | 02:00 PM
91ToyTrck's Avatar
I am always under the impression that when something is dented or damaged that it mean " time for an upgrade ", but maybe that's just my understand when I see things. ;o)
Old Apr 14, 2006 | 02:14 PM
Bobakazi's Avatar
I agree. I ended up going with a double tube Smittybuilt rear. With how many I see dented all the time, one would think Toyota would have a deal with Smittybuilt and put them on stock. I really should edit my last post, but I left my dents on my last '90 for several years, until it got totalled.
Old Apr 14, 2006 | 02:31 PM
AH64ID's Avatar
I agree, I dont wheel enough anymore to just upgrade, but when something needs replacment, well I replace it for wheeling....Kinda why I have a header/hi-flow cat/flowmaster, heavy flywheel and centerforce DF in the garage waiting for me to get home next month....
Its for sure why my truck has an allpro rear bumper on it...dang trees..
Old Apr 14, 2006 | 02:54 PM
Dents I could care less about. A cant to the bumper that keeps me from getting to the spare tire is something I should fix, though.
I'll take it off and see if simply replacing the brackets will be enough.
Old Apr 14, 2006 | 02:59 PM
AH64ID's Avatar
you could solve that problem with a lift and 33's, since a 33 wont fit under there any how :-)
Old Apr 14, 2006 | 03:10 PM
rocket's Avatar
I took off my plastic valance and highly recommend using ratcheting wrenches otherwise it WILL be a major pain in the ass.
The front bumper has 3 bolts on each side:
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
Niameyrider
Jun 25, 2015 05:50 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
TheManOutside
Jun 18, 2015 03:32 PM
