Replacing sliding windows on shell
Old Feb 4, 2006 | 11:48 AM
Asha'man's Avatar
Someone busted out the driver's front sliding window on the removable top on my 4R before I got it, and the PO replaced it with a piece of plexiglass and most of the stock latch assembly. It doesn't quite look, seal, or lock quite right though, so I'm looking to replacing it with a stock window. I found one at the junkyard today, but I couldn't for the life of me figure out how to get it out of the frame without destroying one or the other. And even to get to that point, I had to pull the whole window frame out of the shell, breaking the goo seal that held it in.
How would one go about replacing this window without damaging one's truck?
Brian
Old Feb 4, 2006 | 05:16 PM
lftd_86_yota's Avatar
that sounds tough. especially giving it a watertight seal
Old Feb 6, 2006 | 07:49 PM
Asha'man's Avatar
BTTT. Surely this isn't that uncommon?
Brian
Old Feb 7, 2006 | 06:40 PM
DudeBud's Avatar
may be easier to pull the whole window out and reseal it with urethane.
Old Feb 7, 2006 | 06:57 PM
4Crawler's Avatar
There is a half dozen or so pages in the FSM covering the replacement procedure.
Old Feb 8, 2006 | 03:23 PM
Lt. Dan's Avatar
You will have to remove the entire frame ('goo' and all) To get the windows in and out. Once you have the frame out it's just as easy to just put the whole replacement window, frame and all, back in.
Not too complicated, be carefull not to crack the fiberglass while prying out the frame. WD-40 does a prettygood job of disolving the Butyl Tape.
Be carefull, good luck!
Old Feb 8, 2006 | 09:59 PM
Asha'man's Avatar
Excellent, thank you all.
Is that urethane/butyl/whatever GOO readily available?
Brian
Old Feb 9, 2006 | 11:48 AM
Lt. Dan's Avatar
NAPA, Car Quest, just about any decent auto parts store. Make sure you get the right size. I haven't found anything that is .24 inches. But 1/4 inch Butyl tape is close enough. (.25 inches) Thats what I used on mine anyway.
Good luck!
Jun 1, 2021 01:51 PM
msane99
Jul 17, 2015 10:13 AM
Johntom240
7
Jul 13, 2015 12:18 AM
cyclist231
Jul 7, 2015 12:56 PM
coryc85
Jul 6, 2015 04:07 AM
