replaced oil cooler seals today
Old Jul 15, 2015 | 03:57 PM
mark3913's Avatar
Hey Jason, Thanks for the good details, am planning to do this job this week. Question: if I want to take the oil cooler off but leave hoses on can I just crimp the lower to save the coolant and just disconnect cooler from the top{water} do I need to crimp that one also,can't imagine much water pumping out.Thanks for your help.
Mark
Truckee,Ca.
Old Jun 17, 2018 | 03:23 PM
Paul H.'s Avatar
Bringing back an old thread but mine is now leaking pretty bad on start up so it looks like I will be replacing the seals. A couple of questions first: do I need to drain the oil and coolant? Also is the part number for the seal kit 1036? Thanks in advance.
Old Jun 18, 2018 | 12:37 PM
mark3913's Avatar
Paul, I just replaced the Oring and gasket where the bolt goes thru. I drained the oil but did not remove the coolant lines so didn't need to drain the coolant. the Oring # is 90301-61003 and the gasket is #15785-35010. I changed them without taking the cooler out by leaving coolant lines attached and working with a small needle nose pliers and a dental pic,quite easy to do.Both were pretty rotten and with new gaskets it doesn't leak a drop in well over a year now. Hope that helps.
Mark
Old Jun 24, 2018 | 04:21 PM
Paul H.'s Avatar
Thanks Mark, I found the seal kit, 3 seals, on Ebay for around $13.
Old Jul 8, 2018 | 05:30 PM
  #25
Paul H.'s Avatar
Well I finally got around to doing this today as the weather finally improved enough to not sweat buckets while working. Anyway, I took off the tire and heat shield and what a pain in the butt it was to change those seals especially the large one. I left the cooler attached and trying to get the seal under the tabs with so little room was a major pain. All told it took me about 2 hours from start to finish but thankfully it worked and happy to report, no more leaks. I also left the oil in and only lost about 1/2 a quart at the most.
Old Mar 9, 2019 | 09:19 PM
  #26
Kalihi,HI's Avatar
So I removed the oil cooler and the upper pipe/tube that connects with the smaller u-shaped rubber hose to the engine was full of orange/brown sludge and so is the pipe coming from the engine. I was able to clean out the oil cooler with brake cleaner and compressed air, but what is the best way to clean/clear out the pipe/tube coming from the engine? Pour distilled water down the radiator and hopefully it cleans it out? Any help is appreciated.
Old Feb 12, 2026 | 04:47 AM
  #27
washwalker's Avatar
Coolant flow through oil cooler
When I got my 1990 Toyota Pickup 10ish years ago I replaced all the coolant hoses and didn't think I was getting any water flow through the oil cooler, that the feed from the block was clogged and likely the cooler itself. I am presently replacing the timing belt including installing a new water pump, and noticed that water didn't flow out of the hose from the cooler when I disconnected it from the water pump, kind of confirming what I had noticed before. I seem to remember that the original hose between the block and the cooler was clogged with anti-leak goo and that the blockage extended into the nipple in the block. My question is do I really want to get the oil cooler to function, or should I leave it as it is with no flow, or should I plug the fitting(s) so the cooler itself had no coolant in it so it could not possibly leak coolant. If I don't fix the cooler is it fine to just leave it installed with new seals, or is it better to use an elimination kit? I run synthetic oil and very seldom tow anything, I do do a fair amount of driving on old mining roads but don't do much of any serious 4-wheeling. The rig lives in the desert but is only used during the winter months, but I would hate to have to walk 20 miles out to a main road because of a leaking oil cooler. Thanks.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
