rear windows problem
Old Jan 11, 2006 | 09:38 PM
CraZyRunner's Avatar
My rear windows on my 95 4runner go down very slow i was just wondering if anyone had the same problem? If so are the motors just going out? cause my front two arnt tooo much faster but there is a difference.
Old Jan 11, 2006 | 09:56 PM
Rusty Davis's Avatar
Same here as well as my friend's 94 4Runner and my brother's 95.
Most likely it's the motors. It wouldn't hurt to take the panel off and clean/regrease the tracks but it probably won't help either.
I personally don't even have my rear seats in so they're not a big concern; I just hope they stop working while they're all the way up!
HTH and let me know if you fix it and if it's indeed the motors.
Old Jan 11, 2006 | 10:21 PM
Toyofast's Avatar
Try to spray a small amount of lube into the glass runs. Most likely the rubber is dirty and dry....try a bit of lube before wanting to replace the motor($$$).
Old Jan 11, 2006 | 10:22 PM
farmerj's Avatar
I WAS having the same problem on my 88 4Runner. To solve it I tooke the window apart and cleaned the grease/dirt off of th regulator. Once I did that I regreased it with a good lithium grease and put it all back together. It will now go up and down een when it is sub-zero.
It got so bad before I did this I couldn't even get the window to go up or down when it got cold outside. The grease that was in there was like a stiff glue.
Old Jan 12, 2006 | 07:14 AM
tc's Avatar
tc
Why would you want to put the windows down when it's sub-zero? Brrrrr! LOL
Old Jan 12, 2006 | 07:53 AM
sandcrawler's Avatar
the rear window motor/regulator giving up the ghost is a totally common issue.
i replaced the whole thing (motor/regulator/tracks) on my truck last year. it's expensive, but worth it. you may be able to get away with just replacing the motor and/or regulator and cleaning up the whole inside really well.
Old Jan 12, 2006 | 08:18 AM
4mydogs's Avatar
I think he's talking about the rear side windows, which are very slow on mine, too. In fact, they were slow when I bought it in '97!
Old Jan 12, 2006 | 08:35 AM
you are correct. my bad!
Old Jan 12, 2006 | 08:40 AM
farmerj's Avatar
I would still tear them apart and re-lube them. The lube just gets stiff with the more dust it collects over time.
Why spend a couple hundred on regulators without trying a couple pennies of elbow grease.
Old Jan 14, 2006 | 12:34 AM
I second that. There's definitely no harm in trying to fix them w/out replacing unnecessary parts. Often times the rear windows get dirtier and allow more build-up because they're used less.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
