Old Mar 30, 2016, 10:39 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Interior Guides
Print Wikipost
Radio, Clock and Cigarette lighter not working
Old May 24, 2008 | 04:03 PM
Crawdad's Avatar
I had some electrical problems that I've dealt with, and I'm hunting down the last of the damage. All is well, but the radio, cigarette lighter, and dash clock aren't working - the fuses in the fuse panel in the driver's side kick panel are all good, tested with voltmeter. They are all getting 12v. Is there another fuse I should be looking for?
Old May 24, 2008 | 04:19 PM
woodendude's Avatar
Not sure about a 90 but on my 95 the 15 amp. fuse for this is in the box under the hood.
Old May 24, 2008 | 04:24 PM
Noltz's Avatar
You've check that the fuses are good.. but is there power getting to them?
Check for power @ the fuses. If none, check continuity on the above arrow'ed wire. It's responsible to send power from the ignition switch down to the fuse box.
Old May 24, 2008 | 04:31 PM
Crawdad's Avatar
Yep, all the fuses are getting 12v. Is there another fuse behind the dash? I keep hearing about a fusible link behind the cigarette lighter that controls the radio and clock.
Old May 24, 2008 | 05:08 PM
Crawdad's Avatar
Well, the cigarette lighter and clock are working. The radio still is not.
The lights on the radio come on when the headlights are turned on, but the display does not light up.
Old May 24, 2008 | 05:13 PM
Noltz's Avatar
Nope. After the fuses, they seperate;
Old May 24, 2008 | 05:29 PM
Crawdad's Avatar
Okay, so if the radio fuse in the fuse panel in the kick panel is good, is there a fuse in the back of the radio itself like there are in aftermarket radios?
Old May 24, 2008 | 05:45 PM
just a 22re's Avatar
ok everythings good but the radio right?
you got ground cause it lights up add you need 12+ and ground plus the dimmer 12+ to work the lights in a radio
key and point a relay is used for the lighting of the radio
12+ passes through when the power of the lights on 12+ comes in and snaps to the ground causeing the 12+ from the radio (battery) to pass though the relay to turn on the lights on the radio so i think everythings ok its just that the radio it self is bad did you try turning it on?
take out the radio and test for 12+ ground and lights behind the radio and go from there if you dont have 12+ back there then it between the fuse and the radio thats causeing this hope it helps cause it confused the heck out of me but i under stand these things lol
Old May 25, 2008 | 05:02 PM
Crawdad's Avatar
It was indeed the radio... I put one from a 3rd gen in and it fires right up. Now I can finally reassemble my dash...
Thanks guys!
Old Jul 1, 2008 | 07:56 AM
lward's Avatar
Smile Ms. McGiver
Crawdad, I not sure about a 90 but my dash lights, radio and cigarette lighter were not working. I search this site and under electrical it was the 80 Amp Alternator fuse under the hood in my 1988 Toyota Truck. You cannot just pull it out it is bolted in. There was also other fuses there.
This site saved me over $385.00 the fuse was $2.89.
Old May 27, 2014 | 02:44 PM
toplea's Avatar
2007 Tacoma electrical problems, radio, clock, mirrors and cigarettes lighters not wo
Hey everyone-
I hit a bump one night and my cigarette lighters, mirrors, radio and clock no longer work. The 7.5 A fuse under the dash keeps blowin...Any ideas?
Old May 27, 2014 | 05:39 PM
scope103's Avatar
Well, one idea is to post in the correct section. Most of us have:
"2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS, 85-95"
Old Jan 27, 2015 | 07:03 PM
terik's Avatar
question
cigarette lighter, clock, and radio cut in and out if i use say the blower fan on high, its as if those 3 dont get enough power. if i turn the radio up loud it will cut in and out......if i keep it quiet it wont cut in and out. is it just a weak alternater? ty for any help. new 4runner owner
Old Jan 28, 2015 | 07:12 PM
coloyota1023's Avatar
Just read a post about changing out the power wire that runs from your battery to the fuse box under good. Check there...maybe PO hacked it, you can replace it with 4g or 6-8g works as well. I'll try and post the thread for you to see.
Old Jan 28, 2015 | 07:14 PM
Search fuse box power supply wire in 89-95 section.
Old Sep 30, 2015 | 05:25 PM
Rosscoe Massie's Avatar
THIS POST! helping me see at night and listen to music thank you! after market stereo messing up
Last edited by dropzone; Sep 30, 2015 at 10:47 PM. Reason: please watch your language
Old Dec 21, 2022 | 03:05 PM
Ricta's Avatar
Radio, Clock, Cig Lighter Not working replaced fuses
Hi guys I own a 1998 Toyota Curren/Celica replaced cig/radio fuse and 20a radio fuse turned on car and everything working for like 3 seconds then stopped any kind of explanation for this, thanks.
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
jerusry
Oct 19, 2015 05:28 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
