R150f to RFIA case?
Old Mar 2, 2008 | 10:18 AM
kenai's Avatar
R150f to RFIA case?
Suppose I took a rig with a 22re and was looking to put in a donor 5vzfe with the R150F transmission from a taco. With this tranny bolt up to my stock gear driven case? Have not been able to find the answer, thanks!
Old Mar 2, 2008 | 01:48 PM
jasond's Avatar
No, it wont just bolt up. You can get an adapter from marlin to go from the r150 to the gear drive t-case.
https://www.yotatech.com/forums/f160...z-swap-126413/
This is what I used on mine
http://www.marlincrawler.com/htm/tra...e/taco_box.htm
"34-4GT -> 3.4L Auto or Manual Trans to 4-cyl Gear Drive T/case"
You will also need to convert your t-case to a 23 spline input
Old Mar 2, 2008 | 03:53 PM
tc's Avatar
tc
X2 on jasond's post.
Or you can get the chaindrive case that goes with the tranny, and sell your geardrive.
Around here, geardrive cases go for about $175 from a junkyard.
Old Mar 2, 2008 | 10:20 PM
DeathCougar's Avatar
However, if you get the chaindrive case that goes behind the 5VZ, it will have a drivers side drop, where his 22RE equipped truck has a pass side drop.
Old Mar 3, 2008 | 10:33 AM
tc's Avatar
tc
Duh. Thanks for the reality check DC... skipped right over the "Taco" part I guess ...
Old Mar 3, 2008 | 11:01 AM
lol. Its ok n00b
Old Mar 3, 2008 | 04:32 PM
kenai's Avatar
cool, thanks!
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
