a question... turbo related...
Old 10-01-2007, 08:36 PM
elnino's Avatar
is it worth it turbocharging the 3.0 of the yotas?.....
if it is..anyone has it? anyones sell a turbo kit?...
just wonderring my friend thinks it could be better than 3.4swap...
cheaper,easier,and ...well bad ass...
i think it will be complicated...but..hey im not a yota guy ...help please..
thanks in advance...
Old 10-01-2007, 08:53 PM
RobD's Avatar
I'm not sure, but I don't think the 3.0, in stock trim, handles forced air induction. The headgaskets are already a weak spot, and remember that if you get all that air in, you have to get it all out, too.
You're better off with the 3.4 swap. Easier, cheaper, and faster.
Old 10-01-2007, 09:20 PM
Jay351's Avatar
I have seen it done, there was a link on here to somebody on another forum who did his up with a turbo.
Can't remember the link though, sorry.
Old 10-01-2007, 09:23 PM
apalmer1's Avatar
Im sure you could do it but beforehand you would need to upgrade to a much stronger metal head gasket, and also much stronger head bolts to help it not fail. If it were me i would do that and then get some oversized valves and stage 2 cams, then i think it would be a capable build.
Old 10-01-2007, 09:26 PM
4JOGGER's Avatar
3.OLD TURBOED OR NOT...STILL SUCKS.
It's like trying to make a Model T into a Ferrari. I just don't git it.
I think I will git a Ford instead.
Old 10-01-2007, 09:31 PM
shoes138's Avatar
im turboing my 3.0, im gettin forged rods n low compression pistons from weazy2k, PnP heads with Oversized valves with a custom cam.....
im doing it just to be different....
Old 10-03-2007, 08:39 AM
dcg9381's Avatar
Do a search.. there is someone that successfully turbo'd a 3.0L.
Fuel/timing management is the key - this individual was using an additional injector which was fired only under boost. The ECU was megasquirt, basically configured as a piggyback. It would adjust to a specific desired A/F ratio.
The 3.0L has a head gasket issue, turboing it could cause additional issues. MLS (metal) head gaskets are a good idea.
Do a search, the gains on the stock 3.0 were impressive. Decide what's more work to you vs doing the swap...
TheBFA
02-15-2020 06:55 AM
CPD4runner
9
11-05-2017 06:01 AM
voiddweller
53
02-01-2016 05:46 AM
voiddweller
09-28-2015 11:21 PM
viesail
09-21-2015 06:00 AM
Quick Reply: a question... turbo related...
