PS Rebuild
Old Feb 23, 2008 | 04:49 PM
Sleeper's Avatar
PS Rebuild
Anyone know of a good write-up on rebuilding a power steering unit for a '95 Runner. Just wondering the best way to approach something like this. The rebuild kit is only $40 so I'd rather do it myself and save the other $200 I was quoted for labor. HOw hard could it be? Any help would be appreciated.
Thanks in advance.
Old Feb 23, 2008 | 06:56 PM
Sleeper's Avatar
Bumpity Bump...........No-one can step up to help.....C'mon people!
Old Feb 23, 2008 | 06:59 PM
tc's Avatar
tc
The pump or the gearbox?
http://personal.utulsa.edu/~nathan-b.../steering.html
Personally, I wouldn't bother rebuilding the pump, just replace it.
Old Feb 23, 2008 | 07:38 PM
Sleeper's Avatar
Yeah, I guess I'll price up the unit as well. It's the pump itself. One ofthe reasons I wanted to just rebuild it was because other than the leak there's seems to be nothing wrong. Thanks for the input.
Old Feb 23, 2008 | 08:06 PM
95RunnerSR5's Avatar
its a simple rebuild. the hardest part is getting the pulley off. simply take the old one off and match the parts to the new one
Old Feb 23, 2008 | 08:19 PM
BLKNBLU's Avatar
here ya go
http://members.cox.net/stacewilliams/ps-pump.htm
Old Feb 23, 2008 | 08:27 PM
b.miller123's Avatar
Tc posted the link to the manual, which will help, the other link is good too,
Here is a thread about a guy who had trouble getting his off, I guess that it is pretty common for people run into problems getting a few things off,
https://www.yotatech.com/forums/f120...g-pump-128174/
I gave the guy a couple pointers in that thread, so I won't post a bunch of them up here until you read through it and still need help, then go ahead and ask,
Pointers for the rebuild: buy a toyota rebuild kit, not a cheapy one, and on this thing (the little vsv valve or whatever it is), make sure that you mark which hose goes where, before you pull it apart! I just used a silver sharpie to mark the hose and the plastic valve :
Old Feb 23, 2008 | 08:50 PM
toytech76's Avatar
resealing p/s pumps is very easy. Honestly, the only parts you need to replace are the front shaft seal, the resevour oring, the rear cover oring and the 2 orings inside. The rear cover oring and the 2 orings inside are the large orings. 2 will be a greyish color and 1 black. The 2 greyish ones go on the inside of the pump and the black is for the rear cover. The 2 vac lines on the vsv dont matter where they go. Too bad you didnt live in cali. I would charge you less than $100 to do it
Old Feb 24, 2008 | 10:05 AM
Sleeper's Avatar
Awesome help - thanks a bunch. I'll PM ya b.miller123 if I need help. Go YotaTech
Old Feb 24, 2008 | 10:13 AM
dirtoyboy's Avatar
I usually recommend replacing the pump with a used one.....
pumps are cheap and easy to come by....
100 bucks to rebuild one? hahahha
Dale Johnston
11
Oct 31, 2015 10:22 PM
the_supernerd
Oct 1, 2015 09:20 PM
ktm192k
Oct 1, 2015 08:47 AM
tylermx71
Sep 29, 2015 08:49 PM
voiddweller
Sep 28, 2015 11:21 PM
