Problem with front CV axles 89 4runner
Old Dec 10, 2013 | 06:41 PM
Dan Carey's Avatar
The bolt holds the axle stub inside the hub. Normally you take the outer part of the locking hub off, remove the bolt and washer then remove the hub body off the axle shaft.
Old Dec 10, 2013 | 07:04 PM
Dan Carey's Avatar
This will give an idea of what the bolt does. Although he is working on Toyota without locking hubs, you will see the bolt. The locking hubs use the same configuration.
Old Dec 10, 2013 | 07:21 PM
scope103's Avatar
Oh My God!
That video (as hard as it is to follow) shows exactly how NOT to remove the 1/2 shaft from a Toyota truck! You do need to remove the "gold bolt" (though usually before removing the flange nuts), but you don't remove the large axle nut. And you certainly don't remove the lower ball joints as he was planning to do at the end of the video.
It looks like the author didn't realize that you can't remove the 1/2 shafts with the wheels dangling from the lift like that; the angle of the shaft is wrong, and it won't come out. Instead, you have to lift the rotor as though the truck were sitting on suspension. Remove the cir-clip, the 6 bolts holding the tulip to the diff. flange, and out she comes.
But, to be fair, I have no idea (from this video) what his end goal was.
Old Dec 10, 2013 | 07:26 PM
Dan Carey's Avatar
I agree 100% on the video, posted it to show the 12MM bolt that holds the axle shaft. Here is a better explanation.
http://www.4x4wire.com/toyota/tech/autohub/
Old Dec 11, 2013 | 04:05 AM
  #25
RustBucket's Avatar
Here's the depth measurement I'm talking about. I get 8.5mm as shown in the picture.
Old Dec 11, 2013 | 04:50 AM
  #26
Cyberman's Avatar
Those Milemarkers (or Warn?) might look deeper, but I don't think they are. They just lack that ridge where the stock hubs have the extra snap ring.
EDIT: been a while since I've seen a drafting scale
Old Dec 11, 2013 | 05:05 AM
  #27
RustBucket's Avatar
LOL
There was a day when engineering students had to *draw* before they were allowed to screw around on the computer! I think that changed about the day I got my degree.
Old Dec 11, 2013 | 03:01 PM
  #28
Cyberman's Avatar
Ya, I sometimes miss the t square and lead holder.
Old Dec 12, 2013 | 04:45 AM
  #29
carlspeed's Avatar
Thanks guys! Can't wait to get another cv axle and try this out in 4wd. Abby benefits on going with a cheap OEM axle over getting one from rock auto?
Old Dec 12, 2013 | 05:00 AM
  #30
RustBucket's Avatar
If you have the choice, find a nice set of OEM axles and R&R the boots and grease. The metallurgy is far superior to most parts store axles. I have personally broken at least one Advance Auto axle. My relubed OEM ones continue to hold up well.
6th Gear
19
Dec 10, 2019 07:31 AM
vasinvictor
Jan 20, 2016 12:39 PM
Iceman4193
Jun 28, 2015 10:30 AM
Niameyrider
Jun 25, 2015 05:50 AM
Mohamed
Jun 20, 2002 10:42 AM
