Problem: Cranks, won't start.
Old Oct 26, 2009 | 11:42 AM
Kaydon's Avatar
Snatched one off a truck from the junkyard that runs fine.. well, until now anyway - and no dice. I'm starting to think the computer is fubar.
Old Oct 26, 2009 | 12:30 PM
Team420's Avatar
grab ur multi meter and start testing......its the only way to know for sure.
Old Oct 26, 2009 | 01:20 PM
mcm375's Avatar
Wait so you jumpered Fp and +B with ign on and _nothing_ happened? You didn't hear the fuel pump or fuel pumping through the regulator? Should be very obvious from standing on that side of the engine bay.
If you don't see ~12v on +B then you have blown your EFI fuse. ASK ME HOW I KNOW heheheh.
Check your fuses.
Old Oct 13, 2011 | 09:02 AM
topjmmy's Avatar
Have been reading and testing stil stumped
I have a 90 pickup with v6 auto one day just dies at stop sign. replace fuel pump and coil still no spark then start with volt ohm meter. Have no CEL at all. I don't think I have power at ecu. Shows 1 volt at B+ with key on . EFI fuse is ok no power at fuse with key on. vaf, dist,coil,relay cor all test ok I saw in one thread reset ecu by pulling a fuse ???? Anyone have an idea of what to do next? I miss my little truck but i am not going to continue throwing parts on.
SubiKing
Aug 21, 2021 03:57 AM
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
slider417
Aug 7, 2015 04:29 PM
KBar
Aug 3, 2015 05:14 PM
