Post Your Pics!!!
Old Apr 23, 2013 | 02:02 PM
  #13101
ruffnrowdy1's Avatar
Originally Posted by Dylan86
I vote a solid color like black or navy. Depending on if you're concerned about scratching the sides you can always add bed liner for minor protection.
Yeah the original color was black. We have a little joke with all my friends that black Toyota's are cursed since my buddy had the worst luck with his black toyota I still might go black tho.
Old Apr 23, 2013 | 02:08 PM
  #13102
SLAYfriknBODIES's Avatar
Probably the last pics I'll be taking of my truck before I affect my plans to stick in a 2" lift and put the new tires and Cragar D-windows on. Took it to Turkey Bay OHV for a weekend trail drive.
Attached Thumbnails Post Your Pics!!!-yota-4-1-.jpg   Post Your Pics!!!-yota-2-1-.jpg   Post Your Pics!!!-yota-6.jpg
Old Apr 23, 2013 | 09:36 PM
  #13103
bruno4turbo's Avatar
Originally Posted by toyota4x4907
Tires were fine, I dont have diff lockers. This was the first time I was breaking my own trail in the snow. Right in front of me was a dirt wall I was trying to make it over, but couldn't. Then I just dug down once I rocked it a few times.
my differential teacher taught me how to improvise lockers, with pliers and vice grips. only works for back tires tho. use the pliers to lock up the spinning wheels' parking brake cable, and then use the vice grips to hold it in place while you drive out not a long term or super effective, but it gets you outta a slippery spot
Old Apr 23, 2013 | 09:49 PM
  #13104
Originally Posted by ruffnrowdy1
87 22r 4wd single cab on 32 super swampers. I need some.paint ideas. I plan on using the old style decals on the hood.
go with solid colors, easier to manage, doesn't have to be a dark color either, mines a little on the bright side, works the same with any rattle can color. or just tons of stickers
Old Apr 24, 2013 | 04:15 AM
  #13105
RAD4Runner's Avatar
Nice idea!
Old Apr 24, 2013 | 08:06 AM
  #13106
Nice idea!
its not the safest either (someone has to get under a teetering vehicle), so its more a last minute get me out, then going into a situation you know you'll need it.
Old Apr 24, 2013 | 12:34 PM
  #13107
xtremewlr's Avatar
My daughter's 1991. Work in progress. I just recently replaced the carpet and installed a set of 4Runner seats for her. Still need to get seat covers but she's very happy with the new buckets over the old bench seat.
Old Apr 24, 2013 | 01:27 PM
  #13108
Ocell's Avatar
My buddy John and I hit a creek bed last night.
Old Apr 24, 2013 | 08:48 PM
  #13109
DirtyOregonKid's Avatar
So, the sliders finally got welded on today!
http://imgur.com/r6Ajfxl,ZZIK4QT,68xgYKY#0
Old Apr 25, 2013 | 03:14 AM
  #13110
irab88's Avatar
nice. i need to get myself a pair... of sliders, that it...
Old Apr 25, 2013 | 04:38 AM
  #13111
ChefYota4x4's Avatar
2" lift with OMEmu CS009R 2" lift rear leaf packs and 1.5" bj spacers and 1/2" t-bar adjustment. OMEmu 2"lift nitro shocks riding nicer now up front with 2" up rather than 1" relaxed, hmmmm....
OMEmu 2-2.5" lift shocks riding better now with 1/2 in positive adjust rather then 2" relaxed, hmmmmmm
Old Apr 25, 2013 | 05:57 AM
  #13112
Toyota~Boy's Avatar
Chef that's looking great man. I'm highly impressed at what you done. Nice runner keep it up.
Got any hints to what's next? Lol
Old Apr 25, 2013 | 07:07 AM
  #13113
Hey Toyota-Boy, sup man?
Well, I recently did a resto/mod fest of new rear panels and 3way LED/tailgate-open-activated lighting/Polk DXi 690 built ins/91 Camry driver side rear window motor swap for gate window/fully sound deadened and Frost King Self adhesive foil backed closed cell foam cargo area/front and rear diff breather extensions (rear breather can be seen in 1 of the panel insulation pix)/OEM gate-window Outer weather stripping and replacement (with video and part #'s on build thread)/heater control cable assembly swap (A/C AND HEAT ARE 10X BETTER NOW!, ....plus I can FINALLY operate all the cables with brand new ease! )/ OEM rebuilt 95 4Runner SW13B V6 Calipers, V6 Black Zink Slotted and drilled rotors, 94 4Runner dual diaphragm and 1" bore Aisin Master - cyl upgrade/new t-case output shaft stake nut and both new rear hd u-joints.......
..........But, I have a remaining glitch in the rear window up/down operation that needs fixing(camry motor is 10x better and it flies now!....but it still has the occasional "doesnt wanna open glitch" lol..... And I will be also replacing the inner weatherstripping for the rear gate in the next couple days as well......
I also am about to dig into the pass door lock cyl to get the code for my new OEM ignition lock cyl cut to fit the key set I'm ordering (dealer can see my vin but no longet have any personal code or other specific info on record)..... I will do a full write up of this as well......
Right now I am going to also be adjusting the camber setting as my pass side wheel iscambered on me since adjusting the t-bars back to where it is now. ....
Eeek....
After all I mentioned, I am weighing out the options of some major mods I will eventually do..... I just think I will avoid having ole Ruby Redrum down for another summer (I'm so busy I have to really plan "things to come" out really well! )
Old Apr 25, 2013 | 07:52 AM
  #13114
2toys's Avatar
Looking good chef I wanna do the same lift setup on my 94. I wonder if you'll get any 90 weight stank off that diff breather
Old Apr 25, 2013 | 07:57 AM
  #13115
arlindsay1992's Avatar
I plan on routing the rear diff breather into the fuel filler pocket on my 87.
Old Apr 25, 2013 | 08:40 AM
  #13116
Not a wiff! Lol. ... and thanx
I wanted it in a spot that was free of cold weather (panels are fully insulated) and up enough, and there is a perfect lil tab right there in the panel. Front one is here......
Old Apr 25, 2013 | 08:59 AM
  #13117
lookin good chef! man she's a purdy one, I'm using your pix to try an convince my other sister (not the heep..eeehemm Jeep one) to get a runner
Old Apr 25, 2013 | 09:29 AM
  #13118
Wow, thanks! Haha.... well, tell her I've driven both, and while jeeps can be fun.... they just do NOT have the longevity or durability that these old buggers do.....which has, for most of my jeep owning acquaintances, led to working on them more/HAVING to beefy-mod them more. Plus, the top comes off mine, unlike a cherokee, .......c'momnnnn! Hahaha.
Old Apr 25, 2013 | 09:34 AM
  #13119
Toyota~Boy's Avatar
Chef that's great stuff man. I have both my 93 and 87 that been working on. I've completely parked my 87 trying to get things together for the SAS. Mines not a ordinary SAS tho. I doing a complete frame swap with the SAS so my works cut out there. I've made the 93 my DD so when I start something on it I must finish it the same day. You check out most my 93 work in my build thread.
Old Apr 25, 2013 | 11:03 AM
  #13120
NickMiller's Avatar
Brand new 32x11.50 km2's after I worked on making the paint look good!
