Post your ISR Mod Pics!
Old Aug 29, 2013 | 12:24 PM
  #241
Redeyejedi's Avatar
Originally Posted by clok
can some one please tell me if this isr mod will give the same results as this k&n intake kit does minus the cone k&n filter because i have this k&n intake on my 3.0 already just wondering if i would notice any differance with the 3 inch spectre kit from autozone plus my k&n cone filter ? or should i just leave it the way the k&n kit came, as you can notice this kit came with the bent plastic tube already it was kinda pricey thou....
k&n kit replaced oem air junk. then replaced k&n tubing with spctre, kept k&n filter and mount, opening clearanced to match cressida AFM
Old Aug 29, 2013 | 09:44 PM
  #242
RSR's Avatar
RSR
Wish I would saw this set up before buying my k&n kit , its also about 30-40 dollars cheaper !! Looks like does a good job of keeping the hot air out ? Some data from them would be nice ?
It's all there if you read it. In particular about the heat...
Everyone that's done dyno tests on the K&N cone that I've seen (especially folks w/ next gen 3.4s) actually see a HP and torque DECREASE w/ the K&N. It's never to late to return it. Or sell it on ebay...
Old Aug 29, 2013 | 09:52 PM
  #243
vital22re's Avatar
totally a bro
A little proof on why POD filters and "cold air intakes" are bs.
Old Aug 29, 2013 | 10:09 PM
  #244
RSR's Avatar
RSR
Originally Posted by vital22re
Cold Air Intakes Mythbusted - YouTube
Folks get distracted by confusing more flow w/ more oxygen. It's more oxygen that you need/denser air. Without having an air box (factory setup has), you're drawing in hot engine air, which actually has less oxygen atoms per given volume (is less dense) than colder air of the same volume (hotter means atoms expand and take up more space...). The 3vze engines w/ stock crossover in particular are often 30-50*F above outside ambient air. That reduces some at highway speeds, but it's still hotter than what you get w/ the stock factory setup.
K&N's sound cool but don't deliver more power. They do deliver more dirt to your engine which increases wear and the oil fouls your AFM, making it function less effectively, which reduces your engine's overall performance as well. And eventually necessitates a $300 part replacement... Some good threads on that on here recently. The scruss thread already shared has some really good info -- and that discussion is currently in process.
Here: https://www.yotatech.com/forums/f116...or-mod-272014/
And here: https://www.yotatech.com/forums/f116...-setup-272137/
Old Aug 29, 2013 | 10:31 PM
  #245
clok's Avatar
So it's looking like the s&b kit plus the 3 inch spectre tubing to the throttle body plus the 7mge flow meter is the best way to go on the 3vze ???? And a bored out throttle body !! As far as increased colder air intake is concerend.
Old Aug 29, 2013 | 11:12 PM
  #246
RSR's Avatar
RSR
I don't think the S&B kit is necessary, but it's a heck of a lot better than K&N. One of the folks on the cold air intake thread is doing some restriction/pressure testing in the near future to see where the restrictions are. As far as cold air is concerned, you just need to seal off your air intake from the engine bay (eliminating restriction/increasing air flow over the headlight ensures flow is such that engine bay is harder to draw). And the ISR delete will move your intake tubing away from your drivers side header, which will help keep it cool. But you need to insulate it from the engine bay heat regardless.
Generally for the intake/air flow dynamics of the engine, this is where I'm at (this is the quick and dirty -- details are fleshed out elsewhere):
I think the deflector mod is #1 -- or finding some other way to increase stock air flow. It's not enough w/ base setup... After doing the intake, next look at doing your exhaust proper. Several threads have discussed previously. Mandrel bent w/ crossover delete -- IMO, headers aren't needed. Details in other threads.
If you read through the threads I posted, one of them references something like a 30% increase in air flow w/ mandrel bent air intake tubing rather than the base specter kits, and describes what I'm thinking for that setup... You need to heat insulate your ISR tube regardless... A fairly cheap mod makes this next after exhaust I suppose.
AFM looks like a good mod, but you need to get a wideband 02 sensor to properly tune. So it's a $150-250 mod done right...
I see a benefit from throttle body, but again, if you spend time actually reading the threads just shared, you'll find that before going down the rabbit hole, you need to think through it. Without fixing other items that are greater restrictions, you're barking up the wrong tree.
A huge restriction on our engines as is are the factory heads and undersized valves. So machine your factory heads, or buy new performance heads bored for oversized valves.
To do this, you have to do the equivalent of headgasket job plus you might as well consider rebuilding your shortblock if you're doing the top to not have to do it later... In addition to the valves, you'll want performance cams. $2,000+ later, and only if you've done the stuff outlined above will you want to start on the throttle and plenum...
So w/ $4k+ into the engine not including labor, you might now have an engine approaching the performance of a stock 3.4 5vzfe, but you'll be getting 20% less in MPGs, when you could have just purchased a rebuilt with OEM components 3.4 5vzfe for $3500 that had most of these filter back to exhaust issues fixed from the start... So your call. Just think it through. And read. You get far more info on these boards by searching and reading than asking ?s... Some stuff like exhaust needs done regardless for a 3.4 swap, but by thinking ahead, you can fabricate so that you only have to pay for it once. Make a plan before approaching adhoc. A couple hundred here and a couple hundred there quickly adds up.
Old Aug 29, 2013 | 11:51 PM
  #247
clok's Avatar
Thanks for the insight makes a lot of sense , but I don't know if there's anyone selling a complete 3.4 ltr. Freshly rebuilt and ready to drop in for 3500 , I know there's a place in Oregon called toy swaps only that will drop in a used 3.4 ltr. Into 1 st gen . 4runners but again these motors are used with 175k miles on them , so if you can tell me where I can find a complete 3.4 freshly rebuilt and someone who will install it and proof that it will pass smog in California all for 3500 I'm in !!!!!
Old Aug 29, 2013 | 11:56 PM
  #248
clok's Avatar
Thanks for the insight makes a lot of sense , but I don't know if there's anyone selling a complete 3.4 ltr. Freshly rebuilt and ready to drop in for 3500 , I know there's a place in Oregon called toy swaps only that will drop in a used 3.4 ltr. Into 1 st gen . 4runners but again these motors are used with 175k+miles on them , so if you can tell me where I can find a complete 3.4 freshly rebuilt and someone who will install it and proof that it will pass smog in California all for 3500 I'm in !!!!! Other wise I'm thinking a complete 3.4 ltr used goes for around 2 k and another 1500 to rebuilt it plus around 1500 to install it in a 1st gen 4runner that's around 5k plus it has to pass the smog coach here in California which could be a headache .
Old Aug 30, 2013 | 12:12 AM
  #249
clok's Avatar
Thanks for the insight makes a lot of sense , but I don't know if there's anyone selling a complete 3.4 ltr. Freshly rebuilt and ready to drop in for 3500 , I know there's a place in Oregon called toy swaps only that will drop in a used 3.4 ltr. Into 1 st gen . 4runners but again these motors are used with 175k miles on them , so if you can tell me where I can find a complete 3.4 freshly rebuilt and someone who will install it and proof that it will pass smog in California all for 3500 I'm in !!!!! Other wise I'm thinking a complete 3.4 ltr used goes for around 2 k and another 1500 to rebuilt it plus around 1500 to install it in a 1st gen 4runner that's around 5k plus it has to pass the smog coach here in California which could be a headache .
Sorry for the repost wasn't able to delete first post on my phone , but yeah I know the 3.4 ltr swap is the answer to first gen 4runners but 3500 is not what it's gonna cost to drop in a complete rebuilt 3.4 including labor I know guys on here have done it for around 3500 but they did all the labor them selves and doubt any one them took the time to rebuild them and probably didn't have to worry about smog issues .
Old Aug 30, 2013 | 12:41 AM
  #250
clok's Avatar
I also did the math on a 190 hp 3vze and for a rebuilt one with oversize valves goes for 2k plus 200 to have the heads ported , plus 900 for my mechanic to install it plus already have a mandrel bent exh. System plus bored out throttle body an extra 350 that's 3450 , it will probably be the same hp as a stock 3.4 but it will be rebuilt and installed and know it will pass smog now that I can believe it will cost 3500
Old Aug 30, 2013 | 12:53 AM
  #251
clok's Avatar
Sorry guys didn't mean to get sidetracked on the isr thread .
Old Aug 30, 2013 | 12:31 PM
  #252
RSR's Avatar
RSR
Don't know anything about these guys, but: http://www.yotashop.com/5vzfe-27/
You'd also need all the swap components, but you could probably buy a completely trashed donor, a donor w/ engine already pulled, or even a cash for clunkers donor to pull everything you need off of for $500...
Install and all custom parts is about $1500 to $2000 by ToyOnlySwaps.com once taking away the cost of the engine. So that's $5k full in for what's for all intents a completely new engine versus $3500 for an engine of unknown origins.
Well, found this one for $1500, but that seems too cheap for what all they say they're doing: http://www.123engine.com/toyota2.php
Maybe not, but you'll have to search and see what folks say about them.
Old Sep 17, 2013 | 01:51 PM
  #253
julsruls's Avatar
2 3"to2" rubber things from lowes
1 3" 45degree
spectre filter
adapter
2 breathers
1 piece of 3" pvc
pretty cheap..... most money was the filters
I am already pretty sure I will be coming up with something else in future but for now this works
http://s560.photobucket.com/user/jon...301.jpeg.html]Name:  20130917_122301.jpeg
Old Oct 28, 2013 | 01:57 PM
  #254
pajamawally04's Avatar
Old Dec 28, 2013 | 09:40 PM
  #255
Xeo's Avatar
Xeo
Old Feb 10, 2014 | 09:45 PM
  #256
Nashman00's Avatar
Well this is my new 22re in my auto cross truck
what it looks like now
Old Jul 9, 2014 | 10:28 AM
  #257
iamwieb's Avatar
My ISR.
My ISR pretty happy with it, don't know if I should go with the open filter.
Does it add anything?
I don't really drive through rivers, and live in Texas, we do have pretty good rainstorms but that's about it.
Cost a bit more than I would have hoped but got everything at Autozone and earned my Reward.
Long bent 45 deg. piece 40.00
2.5-3" adapter
3"-3" adapter
6" straight piece.
2 ft 3/8 hose
Attachment 98839
Old Jul 9, 2014 | 11:17 AM
  #258
Roark's Avatar
Originally Posted by iamwieb
My ISR pretty happy with it, don't know if I should go with the open filter. Does it add anything? I don't really drive through rivers, and live in Texas, we do have pretty good rainstorms but that's about it. Cost a bit more than I would have hoped but got everything at Autozone and earned my Reward.
The open filter doesn't really add anything.. It does increase the chances of hydro locking. Unless you're just that concerned about aesthetics, just leave the stock airbox.
Old Jul 14, 2014 | 01:49 PM
  #259
BioHazard050's Avatar
Just ISR'd my '89.
Used a Spectre kit I got from autozone for 50 bucks (hey, its an aluminum pipe), along with an extra coupler, a set of vaccuum hose attachments, and a bit of fuel hose I had laying around. Total cost is around 65.
I had to cut the pipe down by about 2 inches and the pre installed vacuum ports are a PITA , but otherwise its an almost perfect fit. Damn clean looking install to boot! (now if only the rest of my engine looked that clean.)
Old Jan 6, 2016 | 09:34 PM
  #260
Paddler Ed's Avatar
Originally Posted by Cuba
Decided to do this mod and the brake pads as well today. Mainly because when I changed the throttle body yesterday, the intake crumbled to pieces. Was a little bit confused at first by peoples pictures and the lay out of stuff. All is just due to mine being right hand drive though. As it turns out, it's probably a bit easier as I didn't have to worry about clearing the brake master.
I just took a piece of 2.5" tube and bent it. Then flared the ends to 2.75" (70mm) so I didn't need to bother with adapters. Welded a couple of stainless threaded bits that have barb fittings screwed in. A bit of over kill perhaps, but the barbs will unscrew if I need them out for whatever reason.
Anyway, it tidied things up. Breathes a little better, tad more response. Throaty intake sound. Idle up for ps sits up and takes notice far quicker. More serviceable in the future I suppose.
[edit] I just noticed that cable tying that hose off to the airbox clip may not be a good idea
Originally Posted by BEAHRDOG
A RIGHT HAND DRIVE V6!!
I thought I was all alone!
So glad to see another RHD 3VZE as well... most seem to end up with a Commode V6 in them or a Lexus V8....
After a quote of AU$140 for a new intake hose from Toyota (they had been good recently with prices for bits and pieces) I've set off on the making my own option.
So far it's looking like $30 for 3" 45* mandrel bent section of exhaust, and about the same in hose fittings from the local ag supplier.
Now on the subject of those fittings; I can see that I need one for the rocker cover breather, that's easy. What is more confusing is how people have managed the idle up for the PS and AC (AC doesn't have a belt so isn't a problem... lack of PS on the other hand is a problem). In Blu's write up, you can see the spur that it comes off on the lower box (bottom RHS of picture):
Blu's picture from the ISR mod destructions
Am I right in thinking that this is the 2nd fitting that he described as being used for the emissions gubbins, or are the US/Cali spec engines that different that even the vacuum hoses are run differently? On the US market stuff, it looks like the Idle up is controlled via the capped outlet on Cuba's picture and into more plastic that then runs in. Is that correct?
When I look on ToyoDIY diagrams, I get that the hose is for idle up for the accessories, and that makes sense having followed where it runs.
Any feedback? I'm going to be picking up the parts on Monday...
