Ovrrheating getting worse overtime
Old Aug 8, 2016 | 05:44 PM
survivnCA's Avatar
Bought the 87 4runner 4cyl, auto, 4.88 gears, 33 inch tire with 230000 Miles on it with zero background on the cars past. I did a full tube up and started driving. I took it to the hills and it ran great. One day probably on my 6th trip to the hills 120 miles round-trip noticed the temp riding on a pretty steep grade. I changed the radiator hoses and t stat and cap. It ran well and didn't over heat. Till I took it on a long trip and it overheated on a hill again. Well this last trip it over heated on every hill it could. I had to stop and cool down and go again. I don't know where to start. No violent contamination, no milky oil. I did a compression check and the numbers are as follows. Dry 1 = 150 2 = 130 3 = 135 4 = 140 Wet 1= 177/180 2= 165 3= 150 4= 165 Thanks for any help.
Old Aug 8, 2016 | 05:49 PM
lalojamesliz's Avatar
Original radiator?
Old Aug 8, 2016 | 06:14 PM
survivnCA's Avatar
Ovrrheating getting worse overtime-image-4262603939.jpg It doesn't look original. When I flushed it it did have gunk come out. The t stat I put in has a 3/16 hole in the bottom as well.
Old Aug 8, 2016 | 06:45 PM
ewong's Avatar
That radiator looks like a 3 row?
My rad has space in front of the frame cross member.
Granted - thats like the 3rd radiator (370K on the odo)
gap between the rad and the cross member
I usually stuff a 2" block of foam in here (i.e. AC weather strip) - It had that weather strip when new
Old Aug 8, 2016 | 06:46 PM
ewong's Avatar
Off the cuff I suspect HG
A leak down test will help find that..
Old Aug 8, 2016 | 07:12 PM
survivnCA's Avatar
It's always the damn head gasket. Lol. I'm in real deep if that's the case. Do some people opt for a rebuilt motor over the cost of the head gasket replacement? I hooked some compressed air to each cylinder and looked for bubbles in the radiator but there were none.
Old Aug 9, 2016 | 08:58 PM
survivnCA's Avatar
Did leak down test and head gasket looks good. Now what? I looked into the radiator and noticed the top fins were all clogged up. Also when I first spun the fan clutch it spun almost a full turn cold. When I turned it again it locked up. I also did the magazine test on it and it didn't shred it.
Old Aug 9, 2016 | 10:51 PM
ZUK's Avatar
ZUK
new radiator time.
Old Aug 10, 2016 | 11:23 AM
Janos01's Avatar
Originally Posted by ZUK
new radiator time.
Might be time for a new thermostat as well.
Old Aug 10, 2016 | 07:59 PM
survivnCA's Avatar
Stock radiator or v6 radiator? Which is better for the 22re. I've been looking and it confusing. I'll throw a t stat in as well. Toyota stat or 3/16 drilled?
Davebarbier
Mar 27, 2016 04:04 PM
natnat5
Feb 1, 2016 11:01 AM
data
Aug 17, 2002 11:50 PM
