One of my pastic connectors came off
Old Nov 21, 2008 | 12:21 PM
axekick's Avatar
What do y'all do when that happens? I'll try to figure out which plug it is or put up pics as soon as I can.
Old Nov 21, 2008 | 12:23 PM
DeathCougar's Avatar
I hate when pastic connectors come off......
define "plastic connector came off"? Did a clip break?
Old Nov 21, 2008 | 12:38 PM
axekick's Avatar
No, but that has happened on some of the others. I just have them pushed on. They never seem to give me any problems.
The one I'm talking about fell off the wire completely. I can't remember which one it is and I may not get to look this weekend. I was removing my head and it's a gray plug with apparently only one wire going to it. I think it went somewhere near the back of the intake. I'll see if I can find it on a diagram in the FSM on here and post back.
Old Nov 21, 2008 | 12:51 PM
axekick's Avatar
I think it might be the cold start injector connector but I won't know for sure until I get back to my truck.
Old Nov 21, 2008 | 01:41 PM
Tacoclimber's Avatar
When I first read the title...I thought it read, "One of my pastie connectors came off"
I was like, "whaaaat"?
Well, they normally don't just "fall off". Could be that it corroded inside and broke where the wire is soldered/attached. On my 86, there were a few that needed replacing. I found some at a pick-a-part.
Old Nov 21, 2008 | 01:52 PM
PirateMcgee's Avatar
hah I did the same thing when I pulled my head.....
it was the sensor directly in front of the fuel filter....I disconnected it but it ended up getting stuck when I pulled the head
I just pulled the metal terminal out uncrimped it, crimped the wire back on soldered and then put it back in the connector
Old Nov 21, 2008 | 01:56 PM
Keith B.'s Avatar
It's the knock sensor wire. Did it ever have a rubber boot on the sensor? 'Cause the shlubs who put my motor back in left off the boot, on a brand new sensor!
Old Nov 21, 2008 | 02:58 PM
axekick's Avatar
Mine was definitely not the same sensor, I didn't even disconnect the knock sensor. But that can happen with any of the connectors so I knew someone if not everyone here will have dealt with this. I'll try what you did. That is exactly what I was asking for. Thanks PirateMcgee.
some drunk guy
Aug 3, 2021 06:09 PM
Obmi
Sep 10, 2016 04:40 AM
mct75
Aug 22, 2016 01:24 PM
Obmi
Nov 24, 2015 11:37 AM
moparbay
Sep 3, 2015 12:48 PM
