oil leaking out of driver's rear tire
ok i was stumped today, my rear driver's side tire has had oil on it for a couple months now, wherever it is coming from, it get all over the drum (on the outside) and COVERS the inside of the rim in oil...anyway i was in maine today, took a road trip with some friends, well today i saw that the oil had gotten on the outside of my tire, well my friends and i decided to pull the rear tire off and see where is was coming from. the drum was covered in what looked like used motor oil. we whiped it clean and put the tire back on. took it for a ride and heard a squeeking from the rear drivers side tire, almost as it some metal part was rubbing. i checked the brake fluid and the master cylinder is FULL and i also took the truck to a garage up in maine and they said the diff fluid was also FULL, what and where is this fluid coming from it it is not leaking from the diff or brakes??? anyone else have this problem
I just pulled my axles last weekend and swapped the 3rd on my truck so I can tell you that part is easy. My seals weren't in great shape but I don't think they're leaking so I won't bother until they do.
Do you have to get the rear seals pressed in or can you tap them in with a hammer?
For the most part yes, but you'll need the inner seals pressed on. And it might not just be the axel seals, it could also be your wheel cylinder. Thats alot cheaper and easier and less time consuming than pulling shafts and taking em to get the seals pressed on.
if you find its your seals, you might as well do both sides and your bearings. gear oil will strip out the lube from inside the bearings, rendering them useless. get a barbed fitting and extend your rear diff breather while you are underneath.
not what you wanted to hear, but having done seals and bearings within six month of each other, do it now before the wheeling season begins.
lee
lee
hey 89red4x4toyota, i just finished replacing my rear axle seals and bearings and took alot of pictures for you, keep in mind this is for a third gen with a disc brake conversion, but the idea should be fairly similiar
https://www.yotatech.com/forums/show...8#post50470198
Vargntucson
Jul 4, 2015 12:15 PM
nice write up
