new toyota truck
Old Nov 3, 2009 | 06:13 AM
toyota_guy_2009's Avatar
new toyota truck
hi everyone just got a new truck its a 1989 toyota truck dlx x cab.The truck has 176,000 miles on it and just changed the water pump and timing belt and false water pump too.Does anyone know what i should change next?The motor isnt real fast and the truck lags is this normal with these trucks.It does have bigger tires on it 31 10 15 and a 6 inch lift.i just check to see if it had any codes and all is good there.well let me know thanks greg
Old Nov 3, 2009 | 06:16 AM
4runnerteen's Avatar
Well Let me just say Welcome to Yota Tech and grats on buying a toyota lol.
Umm those had the 22r or the 22re engines in them if I'm not mistaken. we call they the 3.slows. They are a little low on the power side and are a bit laggy but How bad is the lag?
Old Nov 3, 2009 | 06:21 AM
chrishf12's Avatar
Congrats on the truck! Do you have any pics? In 89 they came with either a 22re 4 cylinder or a 3.0 V6 and yes they are slow compared to other motors out there. They are not really that bad once you get used to them.
Old Nov 3, 2009 | 06:23 AM
JAC's Avatar
JAC
Welcome!...
Old Nov 3, 2009 | 07:42 AM
shaeff's Avatar
No we don't. The 3.0L 3vze is the 3.slow. The 22re is just a bulletproof, easy to work on, slow 4cyl motor. LOL.
Old Nov 3, 2009 | 07:47 AM
abecedarian's Avatar
Welcome to YT!
As for what to do next... considering 31's and lift, you might look in to regearing.
Old Nov 3, 2009 | 07:49 AM
90-3vzeslug's Avatar
don't let these guys all bust on the 3vze v-6. yeah it's a bit underpowered, and has a hg recall. but otherwise these are just as reliable as a 22r as long as you take care of your vehicle. and they will spank a 22r truck all day long in a race of slugs
Old Nov 3, 2009 | 07:56 AM
search the isr mod as it will help a bit in the power department. also I always recommend a full tuneup on a new to you vehicle. Also if the truck was not regeared when bigger tires were installed it's undergeared now.
Old Nov 3, 2009 | 08:38 AM
Teuf's Avatar
Willkommen
Old Nov 3, 2009 | 08:43 AM
70elcoss's Avatar
Holy! 6 inches of lift with 31's?!?
Old Nov 3, 2009 | 09:55 AM
Smile
thanks guys yeah im not used to the slow truck just wanted to make sure everything was ok w it
Old Nov 3, 2009 | 09:56 AM
Exclamation
hey i also have a few loose wires under the hood and dont know where they go?
Old Nov 3, 2009 | 09:59 AM
Exclamation
ill take pics and post them later and i hope someone will know where they go thanks
Old Nov 3, 2009 | 10:14 AM
MaK92-4RnR's Avatar
take pictures of your truck too.
Old Nov 3, 2009 | 03:37 PM
Grunnen's Avatar
what kind of lift does it have? if its a suspension lift regear/bigger tires. if its a body lift remove it.
Old Nov 3, 2009 | 05:18 PM
it has a full suspension i dnt dnt know what kind
matrad
Aug 26, 2024 08:21 AM
6th Gear
19
Dec 10, 2019 07:31 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
Chooch
Jun 19, 2015 03:05 PM
