New rebuilt no start throwing codes 7 and 11
Old Aug 25, 2018 | 11:10 AM
  #61
87-4runner's Avatar
Hard to start can be another fuel pressure regulator issue... it allows fuel to drain back into the tank...
i just did the jumper wire and was done with that issue after trying 2 after market fpr's...argh
Old Aug 25, 2018 | 11:14 AM
  #62
87-4runner's Avatar
​​​​​This little freak caused me a LOT of headache, time, and money...
  #63
Co_94_PU's Avatar
Fuel pressure..
​​​​There is a rubber diaphragm in the regulator, similar to the pulse damper, while the engine is disassembled this will dry out and may not function as intended when put back on.
Old Aug 25, 2018 | 11:24 AM
  #64
Co_94_PU's Avatar
Ps
Also the one-way anti-drain valve effects pressure retention...
Oh and more importantly charge the battery, checks are invalid cause it's sagging below threshold when you crank again.
Old Aug 25, 2018 | 11:44 AM
  #65
87-4runner's Avatar
thank you, you said it way better than i did!
Old Aug 25, 2018 | 12:57 PM
  #66
outdoorjunky's Avatar
5 Year Member
Alright I can see how that could be an issue since the fuel rail was disconnected sitting in a box of parts with the regulator attached to it for about 3 months before I got the intake back on. Too bad it also seems I’m at the point of needing SST’s to test further or I need to drop 100$ for a new regulator that may or may not be the issue. Got any poor man’s tests for the regulator?
This is what’s frustrating about this issue... I charged the battery by running the truck for a while confirmed 12.6v at battery terminals ... jumpered the FP to get it to start then stopped the engine when it was at operating temp, pulled the jumper off, and look it fires up immediately. Why? Would the engine temp effect the regulator? Does it get bypassed at some point? Maybe a better question is why does it start fine while warm?
Old Aug 25, 2018 | 01:22 PM
  #67
87-4runner's Avatar
No.. once you've started the fuel pressure is trapped for a while... after sitting over night or however long it takes... the pressure leaks off, thus no start till she pressures up again... regardless if you jumpered or not... it's not the fuel pump, its the regulator.
Old Aug 25, 2018 | 01:32 PM
  #68
87-4runner's Avatar
Jumper the FP, put a pair of needle nose vice grips on the fuel line between the fuel rail and see if it starts... NOT gonna happen, why? No fuel, regardless if the pump is working... it still has to get the fuel to the rail...
With the truck running you can feel , the by passed fuel in the (tank return line)... IF the pressure regulator isn't working, but even if it's only kinda working it may not be delivering enough fuel to run right... fuel pressures gauge at the rail willl tell you if it's working too.
Old Aug 25, 2018 | 01:36 PM
  #69
5 Year Member
right I understand it’s not the FP But she won’t really fire at all without jumping Fp and B+ ... she will but it’s extremely difficult to get her to start without jumping. So Am I wrong to think jumping the fuel pump forces the pump to build more pressure than it would if I was just relying on ignition switch priming the pump when the key is in the start position? Seems like all roads are starting to point at the regulator so I’m not arguing that you are aren’t right I’m just trying to understand the “why” in all this and actually I’m not even bummed that I went through all these other troubleshoot steps because I learned a lot, the kind of things that can get me out of a pinch ... real diagnostics rather than relying on OBD2 to tell me what to do like the newer cars do.
so, I’m looking online and even a Napa regulator is 101$ would pulling one from a junkyard be an excersise in futility?
Thanks for your input by the way!
Old Aug 25, 2018 | 01:40 PM
  #70
87-4runner's Avatar
A lot of what I've read in your thread would make the truck run really bad, but NOT keep it from running i.e. timing off, tps off, afm off, firing order off...NOT running is a different animal.
Your running, so it's a process, is it fuel related, or electrical? Sounds like fuel to me... but, I'm not there and I've been wrong before.
i know it can be super frustrating. We'll keep given ya inspiration. 🤔
Old Aug 25, 2018 | 01:46 PM
  #71
87-4runner's Avatar
Might try the pick a part... you could probably get half a dozen of them for $10...
If you get a couple of good ones, i could use one too... lol.
Old Aug 25, 2018 | 01:52 PM
  #72
87-4runner's Avatar
Fuel pressure
Fuel pressure plays a big role in the operation of a fuel injection system. Because the injector is essentially a gate valve for fuel delivery, increasing fuel pressure can allow you to cram more fuel into the intake tract for a given injector pulse width. Typical fuel pressure for a stock 22RTE engine is 43 psi. The maximum fuel pressure that the stock injectors can handle is about 70 psi -- above that and the injector begins to fight the fuel pressure to get its valve open, and fuel deliver actually decreases in volume.
Fuel pressure is determined by both the fuel pump and the fuel pressure regulator. The stock fuel pressure regulator has a hose that connects it to intake manifold vacuum/pressure, so that as manifold pressure rises, fuel pressure also rises, typically by a 1:1 ratio. The pump determines the overall volume of fuel that the system is capable of delivering to the injectors. The size of the fuel lines can also be a limiting factor if fuel demand is significantly greater than stock."
Old Aug 25, 2018 | 02:02 PM
  #73
87-4runner's Avatar
https://people.well.com/user/mosk/EFI1.htm
this is a great read for 22re folks with EFI
Old Aug 25, 2018 | 02:10 PM
  #74
5 Year Member
yeah it stinks that my TPS is also not working properly because I can't even set ignition timing until that gets replaced. this thing is literally just running off eye ball timing from stabbing the distributor at TDC.
Unfortunately regarding the regulator it looks like it was only used on the 22re pickups, 4runners, and the 84-85 celicas that used the 22re. that is unfortunate because here in CA 22re engines are soooo hard to find at the pick n pull. there are teams of professional parts pullers who show up and camp out every day and get all the good stuff immediately as soon as the place opens. I've gotten alerts from the row 52 app on 86 pickups or 4runners early in the morning gone down to pick n pull arriving about an hour to an hour and a half after they open and the truck that was just put on the lot already has no engine, wiring harness, transmission, seats, etc ... it is crazy competitive. I might try to pull a used TPS from a 3RZE 4runner because they seem to get less attention than the 22re trucks and runners but it sure would have been nice if Toyotas use of that regulator was wide spread so I could easily find one.
I know a used TPS isn't ideal but for the moment money is tight. I'm an uber driver but with this truck down I've had to share my work car with my fiancé and I'm also a full time student so finding time for school and working is clashing with her working schedule and hindering my finances greatly. If I can get this thing running right we can trade vehicles as needed and then I'll come back through and replace with new TPS when the financial situation improves. At least now I know how to test a TPS and I'll just bring my volt meter and test it on the spot before bringing it home. as far as the regulator hopefully I'll have some luck tomorrow. I guess I'm already lucky that my fiancé considers a trip to the pick n pull a date LOL.
and FYI If I get a few regulators that work I'd be totally willing to send you one.
Cheers!
Old Aug 25, 2018 | 05:37 PM
  #75
scope103's Avatar
With all due respect to 87-4runner
DO NOT REPLACE THE FPR until you verify that it is not working. How? By checking the fuel pressure against the FSM. Here's the manual:
http://web.archive.org/web/201003261...87fuelpump.pdf
Here's the tool you need:
Amazon Amazon
(this one has the fitting you need, but with the right fitting you can use any pressure gauge).
Yes, the fuel pressure stays up when you turn it off, but it doesn't take "overnight" for it to drain off. There's even a spec; it is supposed to stay above 21psi for 5 minutes (mine barely makes that, and starts right up). But, if your fuel pump is really weak, it could take a while for it to recover from "overnight" (or 10 minutes), making it "hard to start." But trivial to diagnose; get a fuel pressure gauge.
Frankly, I don't think you have a fuel pressure issue. It's probably something as basic as ignition timing. A warm engine can limp along with the timing WAY off, but it is hard to start. My advice: start with the basics.
This forum is full of folks who try to fix their trucks just by replacing parts, almost on a whim, never with an actual diagnosis. Occasionally, someone with a loose wire somewhere will be replacing parts at random, and at some point bumps into that wire while replacing the bulb in the glove box. Did the glove box bulb "fix" her no-start condition? Of course not, but now there's no telling her otherwise.
Old Aug 25, 2018 | 05:50 PM
  #76
5 Year Member
https://www.amazon.com/Actron-CP7838...UKC/ref=sr_1_7
i tend to agree on verifying something is actually bad before throwing parts at it. I just didn’t have 150$ for a fuel pressure test kit and 8.99 for a regulator at the pick n pull sounded a lot cheaper and wouldn’t be too much to throw at the problem if it didn’t work. As I researched more though it’s not really feasible because that regulator isn’t easy to find it was only for 4runners celiacs and pickups up to 88 and then the part number changes and it’s not clear if it works on older models. My plan as we speak is to get my hands on a TPS so I can set proper ignition timing and replace the bad TPS that actually tested bad and was giving off random variable resistance readings. So once I get that step accomplished I’ll be able to see if this is indeed just because timing is off. Thanks for the amazon link 48$ isn’t bank breaking for a tool I should have.
Old Aug 25, 2018 | 10:51 PM
  #77
Co_94_PU's Avatar
Unplug tps, jumper the IDL circuit set the base timing
Measure the fuel pressure before you replace anything.
Warm up protocol sends extra fuel until engine temp is X..
All short hand I don't have time to read and explain, been laying floor since noon, it's 1am
Goodnight
Old Aug 26, 2018 | 06:24 AM
  #78
Co_94_PU's Avatar
So just very wrong I have to disagree.
Inoperable vafm fuel pump switch, never going to start without help. You skipped over this one but the STA signal is necessary also as it's the activation portion of the COR (fuel pump relay!)
Tps not sending IDL, ECU advances timing like you are accelerating combined with not even in the ball park ignition timing. Can cause no start, or worse damage.
Ignition order, just how many sparkplugs does it need to start (remember it was a complete no start at this point not hard start)
Yes you maybe mistaken, or maybe not.
Understand the COR is the fuel pump relay and is responsible for powering on the fuel pump. A high resistance contact in the COR will limit current/voltage availabile to the pump.
There is actually a test for this. It starts with measuring the noload contact resistance, this tells you if it is way out of spec.There is also a loaded circuit voltage drop not covered in the book, but important and usually easy. You can measure across a resistive component (meter probes on input and output) while it is flowing current, the ideal result would be near zero.
Old Aug 26, 2018 | 06:52 AM
  #79
5 Year Member
huh I confirmed voltage at the Fp pin on the COR and all pins on the COR tested within spec although on the higher side of spec. Also the VAFM pins all tested okay as well and when the AFM door is manipulated the COR triggers and the fuel pump comes on. Are you suggesting the VAFM is bad? I may be the one that is bad at testing it. No one really told me if my second round of testing was the correct method. Fp to ground then move AFM door but What am I looking for on this circuit? 12.6 volts when the AFM is manipulated? If I recal my readings were in the MV range not V. Also if the pins on the AFM all tested good via FSM procedure why would the switch be bad? Actually since my battery wasn’t at 12.6v at the time of testing I really should re-run the test on the VAFM and test the COR Fp pin while pulling load (cranking the starter). I got good voltage on the COR while the alternator was charging the system but only pulled 11.79v during the cranking part of the test.
as far as replacing anything else is concerned I’m not going to buy any more parts at the moment until I get the fuel pressure tester which I will order sometime today and should be here by Tuesday.
Old Aug 26, 2018 | 09:58 AM
  #80
Co_94_PU's Avatar
The first bit.. Not directed at you, that is why I separated them.
Check your local parts store, Napa and such, have tool "loan" policies. You can probably get a fuel pressure gauge. They will require a deposit (purchase price), they then refund this if the tool is returned in good shape.
Regarding battery, you showed us a low battery voltage. Easy enough to put a pair of jumper-cables to the other vehicle, that would eliminate a weak battery from the equation..
If you want to you could measure the voltage at the battery, and compare the three scenarios. (Key off, key on, and key in start position.. Most, less, least)
If you have less than 10 volts to the ECU at cranking the ECU turns off, no ECU no injection pulse. The only fuel then is what comes out of the coldstart injector, iirc it doesn't rely on the ecu being powered on.
If your battery voltage drops much below 10 you'll get lots of bizarre behaviors and might hear the relays rapidly cycling..
