New to lockrite
New to lockrite
I just installed a lockrite in the back of my truck and I don't know how it's suppose to feel. It clucked pretty good going straight once but it hasn't done it since. Also I notice alot of backlash in the diff now but when I set it up there was only 5.5 thou backlash in the gears, m buddy said it was play between the axle and the carrier side plates.
I have only been driving mine for two weeks.
Coasting through turns is "freewheels" back there, making a thunking sound, deeper than a tick. If I give it some throttle, chirp!! If I really get on it, drag, chirp, bark, etc, etc. This is all in turns.
I did notice that the auto trans thunks into drive a bit louder with the new diff. Part of that might be the 5.29's, but not sure.
I did not set mine up, it came in the used diff.
Mike
Mike
Well that is not helping your situation at all...It's bad enough having different sized tires on the front and rear but you definitely should have the same size, worn the same, tires on the same axle.
Yes, definitely that could cause an issue. The RPM's of the axle shafts side to side are "wanting" to be differnet even in a straight line.
Did you do research on the Lockrite before buying it?
This is a very common side-effect of it.
Read Matt's thread about it.
You need to make sure all your tires are the same size and close to the same wear on each of them.
As said before, the different RPM's can cause problems.
Fink
Fink
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
pillguy
Dec 4, 2008 04:09 PM
