NEED HELP FAST (Rear DE-FOGGER)
Old Dec 31, 2007 | 11:14 AM
keithguts's Avatar
OK, I took the pannel off of the back tailgate to see if I could find the wires that connect to to rear defogger but have no luck in seeing them. Any idears of where to look, or do I hahe to take more apart somewhere
I have a 1995 4runner.
Having no rear defrosters is a real drag.
Anybody please.....................
Old Dec 31, 2007 | 11:29 AM
stupid_mud_gremlins's Avatar
What type of tailgate, like a truck or is it different? Mine's a first gen, and the wires connect at the bottom of the window on the driver's side. I'll see if I can dig out the heinous manual and find a diagram...
Old Dec 31, 2007 | 11:40 AM
keithguts's Avatar
It is a 2nd gen. As I said, I took the pannel off of the tailgate and removed the plastic stuff they had glued on there, stuck my hand up in there, and I think the wires are broken off. My problem is, how the heck do you get in there to fix them. I can just about get my hand in ther to feel around.
Old Dec 31, 2007 | 11:54 AM
Like I said, no expert on the 2nd gens, but I had to roll my window down a bit to get at the connections. My wires were broken as well, and I couldn't get them to solder onto the connectors. what I ended up doing was taking a couple spade terminals out of an assorted kit I had, and crimping them onto the end of the wires. Of course then the spades on the window connector were to big so I had to cut them a bit narrower with a pair of side cutters, but it worked...until the wires broke again.
Old Dec 31, 2007 | 01:27 PM
keithguts's Avatar
This all sounds good, but I can't get the window to move with the tailgate open. Any idears?
Old Dec 31, 2007 | 02:10 PM
DyeBoi's Avatar
The easiest way for me was to have the gate up, and then drop the window down about half way or so, just enough so that the bottom of the glass was in view through the viewing hole. You'll be sitting in the back with the gate closed. It'll give you easy viewing of the connectors and wires. Pull off the connectors, raise the glass and you'll be able to test if you have continuity at the ends of the wires. If you do, then it could be a grid problem, if you don't, you'll have to keep testing.
I hope some of this helps you out.
Old Dec 31, 2007 | 02:31 PM
Only thing I'd do different is take a spare battery back with me and a couple wires on the posts. That way I could put power direct to the motor from where I am....just saves a few steps. Yeah I know...I'm a redneck....
Old Dec 31, 2007 | 03:53 PM
SKNKWRX's Avatar
On my first gen with the tailgate down I tripped the latch on the drivers side of the gate to make it think it was closed then I could operate the window with the key in the tailgate.
Old Dec 31, 2007 | 07:10 PM
zachb55's Avatar
dont mean to post jack but only about 1/2 of my strips actually work... what have you guys done as a replacement for this? is there a commonly used kit that i could install over the old one to give me something that actually works?
Old Jan 1, 2008 | 10:15 AM
DyeBoi's Avatar
Hey Zachb55, if you're having trouble with your grid lines cause they are cut or chipping, I went to Napa yesterday and was able to pick up some grid repair paint. Its a bit spendy at $10 for a little itty bitty bottle, but if it works, its well worth it. Just visually locate the gaps, or use a voltmeter and then paint over them to complete the circuit.
bigjstang
Jun 2, 2025 03:56 PM
polo451
13
Nov 20, 2016 07:49 PM
jgallo1
Jul 22, 2015 04:21 AM
Fundy Rider
Jul 16, 2015 01:35 AM
icentropy
Jul 14, 2015 10:23 AM
