Name this plug
Old Mar 15, 2015 | 08:42 AM
Scotto6591's Avatar
Name this plug
I have 1994 pickup 22re 5spd 4x4 I can't figure out what it is for there is no spot to plug it in. Does anyone know what this plug is? 2 wire green w/white stripe- brown w/black stripe. Located on intake manifold
Old Mar 15, 2015 | 09:32 AM
Shady Cadence's Avatar
Post a picture?
Old Mar 15, 2015 | 11:03 AM
Odin's Avatar
My 91 22re has a mystery wire and connector as well. I'm not sure of the colors and it's raining pretty good so I really don't want to go out and check it. I was told it plugs into the A/C -IF- the trucks are so equipped from the factory. Mine didn't come with A/C so I just taped it up out of the way.
Old Mar 15, 2015 | 11:09 AM
bswarm's Avatar
Mine didn't come with A/C, radio, speakers, or a cigarette lighter. Yet all the wiring is there, even the speaker wires which were taped up to the main harness under the dash.
Old Mar 15, 2015 | 11:37 AM
Odin's Avatar
Sounds just like my 91. When it was around 90 degrees I thought maybe they deleted the heater control knob too. It just seemed way too hot in there!
Old Mar 15, 2015 | 12:23 PM
Scotto6591's Avatar
Old Mar 15, 2015 | 12:25 PM
Scotto6591's Avatar
Old Mar 15, 2015 | 02:52 PM
scope103's Avatar
EGR Gas Temp sensor.
Old Mar 15, 2015 | 02:54 PM
Scotto6591's Avatar
Thanks
Old Mar 15, 2015 | 06:46 PM
Odin's Avatar
Just thought I'd double check since were identifying connectors.
Is this actually a connector for the A/C on my 91 22re?
The wire colors are:
Black with red stripe and a plain old Blue wire.
The wires leading to the connector comes out of a bundle of wires under the intake plenum. It's the lower cable with the loose black tape on it.
Old Mar 15, 2015 | 07:24 PM
scope103's Avatar
That looks like a connector to a VSV. The A/C VSV (according to my wiring diagram, which is technically for a '94 t100, but has not let me down yet) has a Black-Red and a White-Red.
Do you have A/C? Do you have the VSV, and is it missing a wire?
I can't tell anything from the bundle location, as I have a different flavor engine.
Old Mar 15, 2015 | 08:07 PM
Odin's Avatar
I do not have A/C and the truck doesn't have the dash controller for it.
I looked at the connector in question and it doesn't appear to be missing any wires from it.
I've only been able to locate two VSV's, one Red/Brown and the other is Blue.
Each VSV has a connector hooked to it that is the same color as the VSV it's connected to. I'm thinking they are correct because of the color match.
Old Mar 15, 2015 | 09:05 PM
Odin, that IS for the a/c idle-up vsv, according to wire color. The blue should be hot with the EFI main relay.
Old Mar 18, 2015 | 07:55 AM
Odin's Avatar
So what I was originally told was true.
There was another connector but I'm pretty sure it goes to the factory A/C compressor because it only has one wire and it's hanging between the cold start injection sensor and the coolant sensor.
Old Mar 18, 2015 | 08:18 AM
bswarm's Avatar
When I pulled the heater faceplate off to do the bulb, the a/c switch connector is sitting right there ready to be plugged in.
Old Mar 18, 2015 | 09:18 AM
Odin's Avatar
Kinda sounds like they only made ONE harness for the trucks.
Old Mar 18, 2015 | 09:19 AM
toyota4x4907's Avatar
For the most part Toyota used the same wiring harness for said engine regardless of accessories. You will find a few plugs that go to nothing on your truck but have full use on another.
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
