My runner is dieing 22RE
Old 10-31-2007, 06:31 AM
gametom's Avatar
ok so on my way to work today i pull up to a stop and my idle was under 500rpm ; when i started moving i had NO power nothing and no matter what i did. I could'nt get it above 2k after about 50feet it died. when i try to restart it it starts and then dies, unless i press the gas at the right time, and after that it won't idle Now when i left the house it was fine. now i have noticed that it runs much better when it's cold . i just had my fuel injectors cleaned and tested. my fuel filter was replaced this year and new plugs and wires in the last 1000 miles. it's a 91 4runner 5spd 22re.
at this point i am considering swaping in a different 22re if i can find one cheap
Old 10-31-2007, 07:44 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Did this just start happening all of the sudden? The only incident? CEL coming on?
Start checking for fuel delivery or vacuum leaks. There's three things you need; spark, air, and fuel. It's always one or more of the three.
Old 10-31-2007, 08:03 AM
ozziesironmanoffroad's Avatar
did you check your MAF? maybe you have a vacuum leak, maybe a passage is clogged. these engines seem to be like my iguana... they are masters of being sick and hiding it until its a VERY serious problem. from what you said about it running better when its cold, that leads me to believe its an air related issue. maybe dirty air filter, dirty MAF, dirty intake, etc.
Old 10-31-2007, 08:07 AM
gametom's Avatar
i just cleaned everything intake related.
it was sluggish lately nothing major.
there is no CEL
Old 10-31-2007, 08:11 AM
it doesnt have a big plug on the air box? when that got dirty on mine (88) the truck stopped functioning normally.
Old 10-31-2007, 08:17 AM
gametom's Avatar
i have a cone intake i can post pics later
i had a idea that the slugishness might have had something to do with the o2
Old 10-31-2007, 08:21 AM
thook's Avatar
Hmmm....better when cold, right? Might have something to do with your coolant temp sensor, then. The engine will run richer with fuel until it warms, then it leans out the mix the warmer it gets. If it's not leaning out, you might be flooding. The sensor being bad will definitely affect power and running ability. Do you smell rich exhaust at all?
Old 10-31-2007, 08:38 AM
gametom's Avatar
sometimes,
i have a lot of holes in the exaugst which is going to tell the ecu that it's running lean
::Edited::
Old 10-31-2007, 08:41 AM
linuxrunner's Avatar
I had similar issues when my 02 sensor died. Check a FSM and there is a procedure for testing the 02 (checks if the voltage is oscolating) but i cannot remember it off of the top of my head.
Old 10-31-2007, 08:45 AM
thook's Avatar
Originally Posted by gametom
sometimes i have a lot of holes in the exaugst which is going to tell the ecu that it's running lean
Now that's a detail worth mentioning. Leaks? Before or after the O2?
Old 10-31-2007, 08:51 AM
gametom's Avatar
both.
however if it was really bad should'nt i get a cel
i have gotten a o2 cel before when i unpluged the o2
Old 10-31-2007, 03:07 PM
gametom's Avatar
i'm going to unplug the o2 on the way home
i'm so glad it's only 5 miles home
Old 10-31-2007, 03:57 PM
DilutedImage's Avatar
Patch any holes that are pre-O2 sensor to correct your fuel mixture. If that doesn't correct your problem, then check your timing; it sounds like it may be retarded.
Old 10-31-2007, 06:14 PM
gametom's Avatar
i just did the timing it's at 8 BTDC.
i unpluged the o2 sensor before i left for home and it set the cel.
it will not idle warm or cold now.
i have a feeling it's has something to do with air leaking in post maf.
Old 10-31-2007, 06:22 PM
SCYOTA's Avatar
I'd test your Air Flow Meter and Throttle Positioning Sensor just to make sure they are functioning properly.
Old 10-31-2007, 06:23 PM
thook's Avatar
Yep....that would do it. Of course, uplugging the O2 would not help, either.
X2
Let me get this straight....did you just recently set the timing?
Old 10-31-2007, 07:03 PM
gametom's Avatar
ya when i got the new plugs and wires
Old 11-01-2007, 06:24 AM
gametom's Avatar
there where major leaks in the post maf intake.
now there covered with duct tape till the weekend.
toyota32
07-06-2015 05:42 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
sonic concepts
07-01-2015 02:33 PM
Quick Reply: My runner is dieing 22RE
