mushy brakes that will NOT lock, Ive replaced 90% of the entire system, what next??
Old Mar 30, 2010 | 08:16 PM
V8TOY's Avatar
BRAKES BLEEDING ME DRY!!!!!
First of all this site is awesome! I too have fell victim to the (mushy pedal) it all started when I bought the runner 6 years ago. But I just recently realized how bad it really was so first replaced some questionable hard lines to the lspv, and then the m/c. No change in pedal. So new wheel cylinders and shoes with proper adj/ and bleeding, no change.Next on the list brake booster, guess what? no change. I am to the point that I am loosing sleep over this. I also capped off the rear line from the m/c and where the front line tees off from the pass/ side to the lspv and bled the front brakes, the front held good/ better pressure without the rear brakes hooked up. so then i capped the m/c entirely to check pedal press/ and it held good, to me this eliminates the m/c / booster and any adjustments on them that could cause them to act up.So now I priced a lspv from the dealer cause there is no aftermarket, just a little pricey for me to replace on a hunch $290 to $360. So to rule the lspv out I capped the front line at the tee on the pass/side going to the lspv and removed the rear line going to the lspv and ran the rear line directly to the tee/splitter on the rear axel. And nothing changed what a surprise. So I "bench bled" the m/c again but on the truck I noticed that the first half of the m/c strike the rear line of the m/c got pressure but the front did not, second half the stroke front line of the m/c got pressure but not the rear. I do not know if this is the way it should work or not does any one know ?PLEASE ANY IDEAS WELCOME I AM AT MY WITTS END HERE AND IT SOUNDS LIKE I AM NOT ALONE!
Old Mar 30, 2010 | 08:59 PM
V8TOY's Avatar
Old Mar 30, 2010 | 09:28 PM
kenbo53's Avatar
i know you said you have the rear brakes set up corectly but i had the same problem and thought the mc was going bad but luckily i tryed that first. i adjusted mine out till the drums were a little tight to slide on but once they were on you could hear them draging on the shoes but not really feel any resistance
Old Mar 30, 2010 | 09:50 PM
yotaman85's Avatar
your brake booster diaphragm might have a leak in it.
Old Mar 31, 2010 | 11:11 AM
  #25
Ilovemountains's Avatar
I have the same questions, mine did the same thing when I bench bled the new master!! I dont know what would cause this, Im tempted to buy the aftermarket bigger MC and see it makes a difference... Its scary and frustrating at the same time!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
