mightymouse asked what part of 94 motor was made HELP
Old Aug 6, 2013 | 06:11 PM
BigHoss_27's Avatar
these are numbers i pulled from block 3306992 22r or will any 94 22re harness work on it?
Old Aug 7, 2013 | 12:31 PM
Rerunn's Avatar
What exactly are you asking????
Old Aug 7, 2013 | 12:39 PM
BigHoss_27's Avatar
I have 94 motor in 91 truck And need new harness and trying to figure out what harness would work
Old Aug 7, 2013 | 01:03 PM
snobdds's Avatar
This is the motor serial number, which should match the body and the frame. This means nothing when looking for a wiring harness.
Keep the 91 harness and just transfer over all of the sensors to the 94 long block. Done.
Old Aug 7, 2013 | 01:07 PM
Rerunn's Avatar
Agreed^^^^^
Old Aug 7, 2013 | 01:16 PM
BigHoss_27's Avatar
The two other plugs in cab that connect to chassis and dash harness well the grey plug that goes in the chassis harness is different other then that I could splice other connector on harness but idk about that her is pic of plug
Attached Thumbnails mightymouse asked what part of 94 motor was made HELP-forumrunner_20130807_171544.png
Old Aug 7, 2013 | 01:23 PM
snobdds's Avatar
Your making this difficult on yourself. A 91 22RE block is the same as a 94 22RE block. So, just use the 94 block and all your 91 accessories and harness.
I have a 88 with a motor I had 22repreformance build. I have no idea what year 22RE block is in my truck. But it's not a problem because I used all my original accessories and everything works perfectly.
Old Aug 7, 2013 | 01:43 PM
BigHoss_27's Avatar
What accessories are you talking about?
Old Aug 7, 2013 | 01:50 PM
snobdds's Avatar
Everything...
Alt, starter, intake, exhaust...everything. Just use the long block.
Old Aug 7, 2013 | 02:16 PM
BigHoss_27's Avatar
I bought truck like this and here is pic of plug its bigger then the wiring harness plug
Attached Thumbnails mightymouse asked what part of 94 motor was made HELP-forumrunner_20130807_181550.png
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
