mercury villager electric fan swap
Old Jan 26, 2010 | 06:40 PM
  #61
RustBucket's Avatar
How much did it run ya?
Runnermedic - can you tell us more about swapping a 3VZ-FE Camry alternator in? Is that for the 22re application?
Old Jan 26, 2010 | 06:52 PM
  #62
myyota's Avatar
With shipping and all it cost me about 165 dollars.
Old Jan 31, 2010 | 01:03 PM
  #63
O Holy P's Avatar
On the Villager fan (+) wires, there are 2 for the low and high speed. Both are red, and one has a Yellow stripe and one has an Orange stripe. Anyone know which one is the high speed and which is the low?
Pic below...
Old Jan 31, 2010 | 02:24 PM
  #64
mt_goat's Avatar
Pic below...
I don't know but I know how to find out, just connect it up to 12 volts and see.
Old Jan 31, 2010 | 05:50 PM
  #65
O Holy P's Avatar
I have a 2 speed fan controller and it is working just fine. Took a stab at it and since it's working, I'm gonna leave it alone! Have a Hayden controller and the wires coming from the controller are blue and orange, so just matched up the orange wire with the red/orange stripe and blue to red/yellow stripe.
Old Feb 5, 2010 | 07:56 PM
  #66
myyota's Avatar
For those that have done this mod already, what kind of improvements have you noticed, better throttle response, a little gain in power, better gas mileage, or all of the above ?.
Old Feb 5, 2010 | 08:00 PM
  #67
stormin94's Avatar
I already have an electric fan, but not one of these installed yet. I noticed slightly better throttle response, small gain in power, not so much MPG though. I'm doing the this swap to cool the engine better. I also have better access to the drive belts, and front of the engine without the clutch fan.
Old Feb 5, 2010 | 08:07 PM
  #68
O Holy P's Avatar
Yea what he said, but I noticed a bit more power under 3500~4000 rpm for sure. I live in So. Fla so it seemed like my clutch fan was always engaged, and I could immediately tell the difference and it is nice. I haven't run a full tank of gas through yet, but I believe the engine is working easier on the highway, I can feel the little extra power and less drag. So I assume my M'sPG will go up.
Old Feb 6, 2010 | 09:52 PM
  #69
aviator's Avatar
Just found a pin hole in the raz a frazzin radiator... bars leaks is holding it for now it seems... think I'm gonna do the efan swap when I throw a new rad in in the spring once it starts warming up (if the thing lasts that long ^touches wood^)
Old Feb 7, 2010 | 10:26 AM
  #70
myyota's Avatar
For those that have done this swap, lets see some pictures of the fan mounted up to the radiator, some pictures of it wired up and a little more information on what all you did to make it work.
Old Feb 7, 2010 | 10:30 AM
  #71
N204life's Avatar
I dont think mine is a villager, but its off a mercury with a 3.8l v6. Looked late 80's early 90's.
Old Feb 7, 2010 | 11:03 AM
  #72
DJ99's Avatar
There's a lot more in this thread:
https://www.yotatech.com/forums/f116...n-swap-193061/
This thread has wiring diagrams, and some pictures.
I didn't provide pictures, but here is what I did. I bought a brand new villager fan, and cut it down to fit inside the stock radiator shroud. No need to remove the radiator, but it helps to drain some coolant to remove the top hose. I mounted the electric fan inside the shroud with some bolts and spacers to make it sit closer to the radiator, and more importantly, away from the fan pulley.
Old Feb 7, 2010 | 11:07 AM
  #73
iamsuperbleeder's Avatar
that IS this thread...
Old Feb 7, 2010 | 11:28 AM
  #74
O Holy P's Avatar
pics 1
Old Feb 7, 2010 | 11:29 AM
  #75
O Holy P's Avatar
pics 2
Old Feb 7, 2010 | 11:30 AM
  #76
O Holy P's Avatar
sensor...
Old Feb 7, 2010 | 11:39 AM
  #77
DJ99's Avatar
Oops, I thought somebody started another thread. Then there's no excuse but to start at post #1 and start reading!
Old Feb 7, 2010 | 01:29 PM
  #78
stormin94's Avatar
Where did you get the two speed controller?
Old Feb 7, 2010 | 01:32 PM
  #79
O Holy P's Avatar
Summit Racing, it is a Hayden 3654 dual speed 2-fan controller. I plan on hooking up another 8" fan to my newly installed condenser.
http://www.summitracing.com/parts/HDA-3654/
Old Feb 7, 2010 | 01:47 PM
  #80
stormin94's Avatar
So, with that controller can you adjust the kick point for both speeds of the fan independently?
