Loss of voltage when braking
i got a 91 pickup 22re and when I have the lights on and apply the brakes the battery meter goes to almost none and theres a small squeal. wondering on what this might be
x2 on the alternator, but could also possibly be battery, a bad ground, corroded connection, or a corroded wire.
If you find it to be a bad alternator, make sure the battery has a full charge before firing it up for the first time once you have replaced/repaired the alt.
basically, it's all pointing to your alternator. When you brake, your rpm's drop, in turn not spinning your alternator enough to create enough power. It could be a couple of things, your belt could be old, your alternator could be bad or your voltage regulator could be going out (I'm not sure if they're integrated into the alt. on yota's or not). Do you have any extra electronics in your truck that pulls directly from the battery, say maybe an amp to a sub or anything? If you do, you may want to install a capacitor in the power line. Either way, your alternator isn't getting enough spin to give you ample power. Check your belts first since that's the easiest and cheapest fix. After that, I'd say run your truck for about 20 minutes and then disconnect the positive battery cable. If it dies, your alternator is donzo.
I don't recommend disconnecting the battery when the vehicle is running. It acts as a very necessary capacitor itself, kind of like a surge protector. At least, that is what we were taught in school, and it makes sense to me. Everything else sounds good though.
This happened to my '86 the other day. Turns out my battery was loose and when I braked the battery would lurch forward and disconnect. Then lean back and reconnect... didn't learn this until I tore already took the alternator off just about and noticed that the wire was loose on the battery. Life's tough.
Tacoma1313
Aug 17, 2015 05:44 PM
Koolbananass
Aug 12, 2015 01:59 AM
Johntom240
7
Jul 13, 2015 12:18 AM
