long travel suspension
#61
Lol, that doesn't really apply to long travel IFS kits, there is ether expensive, or REALLY expensive. The only thing with downey's is that they use stock like A-arms and torsion bars, and claim REALLY good flex, but i just can't see it.
#62
in terms of torsions, so does the TC kits unless you get the caddy 2, which allows you to run coil overs. I personally envisioned sway a way torsion bars with the uniball kit, and doestch Tech remote reservoir shocks.
#65
Right, but there are some things that i really like about the Downey kit, like their CV, and balljoints, but there is more that i don't like, namely, not having stronger torsion sockets. If downey's kit was like 1500 out the door, it would be awesome, buts its a little over 2k, and thats not worth it to me with a kit that retains torsion bars, at that point you might as well keep saving for a coil over kit.
#66
my buddy ran the downey kit on his old taco, he wasnt very impressed and was kind of pissed cuz he had to reweld the passenger side A-Arm 3 times in like 2 years. then he sold the truck and bought an F150 with a TC kit already on it. he loved it, would jump it, mud it, take it swimming, etc. now the truck is sold and hes in the army, go figure. lol.
#68
#71
I like what you did with the rear shocks, do you get any tire rub at all? I was thinking of keeping them on the inside of the frame but tub a chunk of the rear cargo area.
#73
#74
Miss read your original post. Sorry. I would run a cage up inside and then put a rubber seals in there to seal holes off from the elements. Might be easier then tubbing the floor. Easier to adjust shocks too.
#75
I was thinking about that, too. Could make a tube crossmember that comes through the floor so the shocks could mount higher and then use a heavy rubber mat of some kind to cover it. Screw it down and have the reservoirs mount inside the truck so that i could adjust them from under the back seat. I was thinking that if i did a cage, I would do an exo-cage so i would not have to make the interior any tighter than it already is.
#77
I cant believe I forgot about Camburg.
ready for the wheels to spin? Check the rear tub job.
http://www.camburg.com/xvehi4Runner.html
I think this might be the one I remember from the mag, doesn't look the same though,
http://www.off-roadweb.com/features/...er/index.html:
More rear suspension ideas:
http://www.tacomaterritory.com/forum....php?p=1216498
2 parts on this rig, but more ideas. 4th gen Runner:
front
http://www.toyota120.com/forum/showthread.php?t=1870
rear
http://www.ultimateyota.com/index.ph...=4970.msg47578
Now GET TO WORK!! lol
front
rear
#79
I forgot to mention that when I was doing google searches on long travel for toyotas and 4runners, Downey did not make it in the top 10 on any inquiries I made through google. That should tell you something.
#80
yea it sure does.. the tc kit is running away with my votes that for sure lol
