long travel suspension
Old Dec 8, 2008 | 12:20 AM
afnf_life's Avatar
lol im just saying lol im curious if it could handle a jump that high
yotasavg's Avatar
haha i get that much air with my OME suspension....stock travel essentially
the TC kit can take that for sure
the downey most likely can too
Old Dec 8, 2008 | 12:21 AM
afnf_life's Avatar
really on stock suspension??
Old Dec 8, 2008 | 12:24 AM
91Toyota's Avatar
I wouldn't find out! It takes A LOT to handle that kind of jump. Ask these guys...http://www.dezertrangers.com/vb/
Its not as simple as it sounds...you'll break other crap.
Old Dec 8, 2008 | 12:25 AM
  #25
yotasavg's Avatar
i get at least 3-4' of air....wish i had pics for you but the only time i've prerun with a camera i haven't had another person to take pics, not to mention i don't like to hit one spot over and over.....i just like to haul azz
  #26
yotasavg's Avatar
one cv so far.
Old Dec 8, 2008 | 12:27 AM
  #27
afnf_life's Avatar
dang that crazy lol do you break alot of stuff??
Old Dec 8, 2008 | 12:28 AM
  #28
afnf_life's Avatar
well then if i get the downey set up i should be good to go?? lol
Old Dec 8, 2008 | 12:32 AM
  #29
afnf_life's Avatar
ok looking at the downing website and there new long travel suspension system it has a bunch of different part numbers.. and im confused on what i need.. for the whole system do i get the grand slam kit or what??
Old Dec 8, 2008 | 02:02 AM
  #30
yotasavg's Avatar
you would need either the 2 or 4wd kit under where it says "COMPLETE FRONT SUSPENSION ONLY" $2563.00 and $1851.00
2wd is the same minus the custom axles btw.
Old Dec 8, 2008 | 08:15 AM
  #31
sa51's Avatar
hehaha i've jumped my stock tacoma trd [rip] about that high before as well...........ended up finding a broken leaf later that day
Old Dec 8, 2008 | 08:41 AM
  #32
stagger_lee's Avatar
If you are going to pay $3k-$4k, go with total chaos. Only for the fact that thats what they do, exclusively, developing long travel kits. Downey does it all. Nothing against Downey, but they aren't focused on that and it is a newer concept for them.
Old Dec 8, 2008 | 09:35 AM
  #33
scuba's Avatar
Stagger makes a great point
Old Dec 8, 2008 | 10:04 AM
  #34
yotasavg's Avatar
yup. i totally third that.
Old Dec 8, 2008 | 11:22 AM
  #35
Alex 400's Avatar
the nice part about TC LT kit is that it uses t100 axles that you can get over the counter. Downey makes you use their axles which if you break them you got to order them through downey.
Old Dec 8, 2008 | 11:24 AM
  #36
Yotas&Jellos's Avatar
Check out Duffco, I hear they've been around for a while.
http://www.duffcoenterprises.com/toy84-95_2wd.htm
You need to call to find out how much their LT kits go for, but you could probably work 'em down a little over the phone.
Old Dec 8, 2008 | 11:28 AM
  #37
You can get the T100 axles from the junkyard for dirt cheap.
I don't think Duffco has a 4wd LT kit. Look at those pics of the lower arms from Duff and compare to Total Chaos. Chaos are boxed and damn stout looking. Chaos can take a beat down. I have seen it first hand.
How do you plan and making your rear keep up with the front? You going to run a shock cage inside the cab rear? You don't want the rear to pop on a jump when the front eats it up. It will throw your rear up in the air.
Old Dec 8, 2008 | 12:06 PM
  #38
mrmatson's Avatar
I just bought mine kit from Total Chaos, and has been said, it's pretty expensive. But the quality is just phenomenal, which makes it worth every cent.
Old Dec 8, 2008 | 12:20 PM
  #39
afnf_life's Avatar
ok i am now thinking of the tc kit cuz there were some good points made..
but if i got the COMPLETE FRONT SUSPENSION ONLY fron downey what kit do i get for the rear??
Old Dec 8, 2008 | 12:22 PM
  #40
Alex 400's Avatar
the idea that i had for the rear would be similar to what TC did except try and make the arms a little longer, and use coilovers through the floor.
