Light bulb for a/c indicator button?
Old Jul 7, 2019 | 05:18 PM
I8URSVT's Avatar
Hey all, trying to source the a/c indicator light bulb for the 84-88/89 trucks/4runner but cant seem to find it. Does anyone know the part number and/or place I can order one from?
Old Jul 9, 2019 | 12:15 PM
TLfromAI's Avatar
Is it the same switch as the '91? I had the same issue. The switch worked but no light. Replaced it with this:
https://www.amazon.com/gp/product/B015OECK5O/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B015OECK5O/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
It was a little tighter fit but it worked for me.
Old Jul 10, 2019 | 07:37 PM
I8URSVT's Avatar
No, its just a little button that you put out and there is a very small bulb but cant seem to find it anywhere, let along find a picture to show it
Old Jul 10, 2019 | 08:09 PM
old87yota's Avatar
The Toyota parts diagrams ( that I have found anyway) do not show the bulb itself for the A/C button, just the whole switch assembly.
Chances are good that Toyota used the same bulb in other switches or applications, but I have no idea which ones.
Old Jul 11, 2019 | 06:14 PM
Paul22RE's Avatar
5 Year Member
For my '92, the LED replacement bulbs (edit: for illumination only) that fit in my switches are size T3 and looked like this:
I am sure you can also find regular T3 bulbs if you don't want LED, I found the LEDs on eBay.
Old Jul 21, 2019 | 04:39 PM
scope103's Avatar
Paul22RE: Those bulbs are to illuminate the switch when you turn on the headlights. (On my '94, I have a T1 size bulb, but it looks like your bases will fit and so the bulb size doesn't matter.)
if I8URSVT is asking about the indicator bulb, so far as I can tell it's a built-in LED and can't be replaced separately.
Old Jul 21, 2019 | 05:47 PM
Melrose 4r's Avatar
5 Year Member
Wow, i was just about to post/search this same question about the indicator bulb.
second, how do you remove the switch, or panel? If i can get to the led, i’ll try to fix it.
Old Jul 22, 2019 | 04:22 AM
Paul22RE's Avatar
5 Year Member
The switch just pops out in my 92 without removal of anything, but maybe because the tab for the electrical connector in the back is missing? I double-checked, Scope103 is correct: the T3 bulb is just for illumination of the switch, the tiny green "on" light is internal and does not appear to be replaceable. Best to just find a used switch on eBay.
Old Jul 23, 2019 | 08:54 AM
I8URSVT's Avatar
the light im referring to is green button in photo. I believe it is specific to 84-88(89) pickups and 4runners. You have to pull the front of the dash off to access it (At least I did). Hoping someone has a part number or source to get the bulb. I pulled the bulb out before, so i know it can be replaced by itself.
Old Jul 23, 2019 | 09:37 AM
scope103's Avatar
Well, one COULD try the dealer.
84999-10110 https://parts.lakelandtoyota.com/p/_...499910110.html
https://parts.lakelandtoyota.com/p/_...193089111.html
I'm not familiar with your vintage truck, so I don't know if there is an illumination bulb distinct from the indicator bulb.
mldave
Feb 25, 2012 09:32 AM
Dug
Nov 6, 2006 09:41 PM
Heebz
17
Sep 29, 2003 12:31 PM
Cash4
Apr 4, 2003 05:40 AM
