Its baaack - 7mge VAFM swap for the 3vze!
Old Oct 11, 2013 | 02:18 PM
  #141
bone collector's Avatar
probably the fuel pump activating
Old Oct 14, 2013 | 11:24 AM
  #142
Redeyejedi's Avatar
that is what i thought as well.
having starting issues.
gonna do the test to see if fuel is getting to rails.
could it be the cressida vafm not sending a signal?
Old Oct 14, 2013 | 11:41 AM
  #143
Its possible. Better check it per the fsm
Old Oct 14, 2013 | 01:48 PM
  #144
Redeyejedi's Avatar
diagnostic port? jump Fp B+?
going off...... http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Oct 14, 2013 | 02:46 PM
  #145
yes. test the fuel pump using 4 crawlers method, but also test the afm using the link below.
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
Old Oct 16, 2013 | 10:34 AM
  #146
Redeyejedi's Avatar
no codes.
i hear the noise from the pump towards rear
i hear a noise when b and fp are jumped
checked vafm resistances, all good.
changing fuel filter this evening(not sure will have an effect but have one anyway)
Old Oct 23, 2013 | 12:51 PM
  #147
Redeyejedi's Avatar
fuel filter fittings fun!!! Forkn fittns! had to cut out line, and filter to remove/replace. nasty runny dirty oil lookinf fuel drips from filter IN. dripped maybe 1/2 to 3/4 cup of fuel.
6AN to 14mm then a barbed fitting to 3/8 high pressure hose. but that hose loosely fits on fuel line. still no start, vafm checks out per resistances at terminals from fsm link.
swapping back oem vafm to rule out.
UPDATE:
was the vafm. swapped stock back in and started right up. curious as the donor vafm from the 90cressida initially passed resistances. have a 'new' donor vafm and going to tune when time provides. when dialed in this and the other mentioned mods in the air/exhaust system make a wonderful difference while retaining the ability to revert back stock or at least very near to.
props to you guys for embarking this experiment.
Old Oct 27, 2013 | 01:24 AM
  #148
JackHammer's Avatar
I did this mod and it's working great so far.
Old Sep 13, 2016 | 04:19 AM
  #149
Joe1's Avatar
results
Has anyone done a before and after dynamometer run with this mod? Not seat of the pants " I feel it's better" actual scientifically measured results. THe math I have read says it shouldn't make a measureable difference because a stock engine just can't move enough air.
Old Sep 13, 2016 | 04:43 AM
  #150
cbr600rx7's Avatar
The correct term you are looking for is dyno. And it does not give you actual scientific evidence other than peak HP/TQ numbers at WOT. It does not show real world comparisons like driving down the high way at part throttle or normal driving conditions. The VAFM is clearly one of the most restrictive parts of the intake system along with 90 degree that tapers down to under 2.5 inches in places. The throttle body is a resonable 2.75 so after the ISR mod this seems to be a good investement.
I don't think your going to see many people rushing out to dyno 120whp trucks that are worth maybe $2000-$4000 any time soon. The only way I see any one investing that kind of time and money into a 3VZE is if they are trying to dial in there timing and AFR and 99% of us do that by street tuning.
Old Jul 24, 2018 | 10:30 AM
  #151
chefdave's Avatar
Had another go at this mod
Reserecting this thread. Had another go at this mod. More success this time. Still need to to dial in fuelling but waiting for new dizzy cap, rotor arm and ignition leads. Engine is missing slightly which it did with old vafm. First feeling is lots more torque can feel feel body rock if I rev engine. Throttle feels lighter and more responsive. Will give more feed back after new parts fitted.
Old Mar 14, 2024 | 06:39 AM
  #152
redrunna4's Avatar
Need some advice
seen this mod and hoping i can do it, does anyone think it would work with the automatic trans in mine or would the ecu go crazy??
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
smiley52
Jul 11, 2015 05:16 AM
