Ignition problem no start
Old Oct 11, 2008 | 01:20 PM
huntnfreak's Avatar
I have a 90 4runner 3.0 and i have replaced the starter and cylanoid on the starter and the truck had no problems until today i drove the truck all day start and stop at the stores and then at end of the day it took about 10min. to try to start it. i didn't here any noise outside of the truck no clicking sound like before this happened. So i was woundering if there has been problems for the ignition cylinder or the ignition switch. Please need info.
Thank you Tony
Old Oct 11, 2008 | 02:17 PM
just a 22re's Avatar
did you check to make sure the wires are tight on the starter and battery my battery cable got loose on me and did the same thing
Old Oct 11, 2008 | 04:47 PM
huntnfreak's Avatar
i will check the wires 2nite, I talk buddy of mine and he said to check to starter relay.
Old Oct 11, 2008 | 06:12 PM
fireman1559's Avatar
are you sure its your starter? my truck died its the 3.slow and my ignitor went out and it wouldnt start it would just kinda shake a bit then stop
Old Oct 11, 2008 | 07:35 PM
huntnfreak's Avatar
I just replaced the starter a month ago. because of this problem, but it was making clicking sound coming from the starter. The truck is starting just fine now so i think it might be maybe the ignition relay or the ignition switch. If it was the ignitor would it still start every so often.
Old Oct 12, 2008 | 07:11 PM
nope it wouldnt mine just sat there it worked fine up until it died it will go out slowly my truck acted up for like a week like die and come back everynow and then then one day it wouldnt start
Old Oct 12, 2008 | 07:16 PM
abecedarian's Avatar
battery?
Old Oct 14, 2008 | 04:36 AM
huntnfreak's Avatar
battery is good
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
bigblue82
10
Jul 6, 2015 08:27 AM
MadMax48
Jul 3, 2015 08:26 AM
rbravo1
Jun 29, 2015 01:34 PM
