which idler pulley is this?
Old Feb 1, 2006 | 01:06 AM
radrav4's Avatar
was wondering which pulley is this, i have a 91 3.0 and just took off the water pump and the pulley that's attatched (the one the spring attatches to) and did not find no washer behind it. Is it the number 2 idler pulley (water outlet housing? why is the washer so important, does it act as a spacer for proper timing belt alignment? here's the pic of the washer
http://www.off-road.com/toyota/tech/v6tbelt/
Old Feb 1, 2006 | 01:07 AM
radrav4's Avatar
sorry here it is
http://www.off-road.com/toyota/tech/v6tbelt/0716.jpg
Old Feb 1, 2006 | 03:29 AM
callmej75's Avatar
The one on the left hand side of the picture http://www.off-road.com/toyota/tech/v6tbelt/0708.jpg
Not the center one at top...
Old Feb 1, 2006 | 03:47 PM
bike hauler's Avatar
It is the #1 idler pulley,or the tensioner pulley.The washer is to allow the tensioner to rotate with spring pressure to set the tension.
Old Feb 3, 2006 | 08:28 AM
radrav4's Avatar
thanks guyz
thanks for all your help, my idler pulley is slightly different than the picture I guess the 91's are different than the 92's and up. I looked and looked to see if I dropped that washer but can't seem to find anything, I'll try looking at a parts fiche or dealer, anyone got a 91 and earlier to confirm this?
Old Feb 3, 2006 | 07:01 PM
radrav4's Avatar
update on the washer
just wanted to give everyone a update on my washer fiasco..TRDparts4u confirmed that there is no washer behind the idler pulley on my year 4runner which is 91, i suspect the 91 and earliers did not come with one. Thanks everyone for all your help..whew!!
Old Feb 3, 2006 | 07:02 PM
callmej75's Avatar
Good deal...the guys over there are an enormous help when ya need it
Old Feb 7, 2006 | 12:29 PM
VA_Yotaman's Avatar
Glad you found out. I was nervous when I did mine because I followed the same directions that you did, and it specifically said not to lose the washer. Disregard my PM.
ladybugRC
458
Aug 21, 2020 10:41 AM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
EVars
Sep 29, 2015 02:06 PM
voiddweller
Sep 28, 2015 11:21 PM
