identify leaking parts? (91 4runner 3vze)
Hello, I bought a 91 4runner 3vze 5sp a couple weeks ago. It's been sitting in the garage since then. I noticed some random drops of oil/fluid on the garage floor. The valve cover gaskets have a couple leaks I noticed, but there is no oil below them. So I pulled the front skid plate off and grabbed a flash light and noticed some places where the drips are forming.
This is on the passenger side of the engine bay.
The brake line fitting on the right leaks when the brakes are applied
This picture is from underneath on the passenger side. I believe this is the power steering pump.
This picture is on the driver side of the engine bay. It has to do with the steering shaft I think.
Sorry if my description is vague. Any help identifying these parts would be greatly appreciated.
Thank you.
Thank you.
#1 is the ABS actuator http://personal.utulsa.edu/~nathan-b...13generald.pdf It's plumbed for both brake and power steering (it's "powered" by the PS pump).
#2 is the power steering pump. It's filled with ATF not "PS fluid," which is why it looks pink.
#3 is the PS Gear housing.
WHENEVER you have a leak, you will save yourself a lot of time by cleaning the engine with spray degreaser and a garden hose. Get it clean enough to eat off. Gravity is not your friend; a leak near the top of the engine always makes a mess at the bottom, so you need to clean it up first to find the source.
voiddweller
19
May 2, 2016 09:10 PM
