How to remove intake from 22re!?
Old Aug 5, 2006 | 04:12 PM
mtrdrms's Avatar
Well I am balls deep in this headgasket replacement and I just cant seem to separate the intake from the head. Is there a trick here? The exhaust was a breeze but this intake is giving me a migrane!
Old Aug 5, 2006 | 05:10 PM
Lunnzz's Avatar
There is a allen head bolt right by the thermostat it is hard to see did you get that?
Old Aug 5, 2006 | 05:56 PM
mtrdrms's Avatar
no i did not
Old Aug 5, 2006 | 06:03 PM
4runnerx3's Avatar
When I took mine off, I looked at my new intake gasket to figure out where all the bolts/studs were. I used a socket with the universal joint made on them, that really helped. I think I invented a few new yoga postions taking that thing off. And there's that allen bolt, very long, goes right under the thermostat housing.
Old Aug 6, 2006 | 08:18 AM
slacker's Avatar
here ya go
Old Aug 6, 2006 | 05:10 PM
mtrdrms's Avatar
THank you! That was the one I missed. Now if I can only get these dam wires out of the way!
Old Aug 7, 2006 | 05:00 AM
Lunnzz's Avatar
Did you seperate the intake into two pieces if not that might make it easier to get the wires out of the way it's what I had to do.
Old Aug 7, 2006 | 06:44 AM
SupraSport's Avatar
Deffinately seperate the intake pieces. There is also a metal coolant line attached to the bottom of the intake, make sure you disconect that too.
The 22re intake can be pretty tricky, don't mess up the vacuum line else you nwill be kick ing yourself
Old Dec 11, 2012 | 12:40 AM
bwalters9762's Avatar
I can't get this metal coolant line out of the way, I can't figure out where the best place to separate it is
Old Dec 11, 2012 | 12:45 AM
wyoming9's Avatar
Red face
it is a two piece manifold
your not getting the wiring harness out with the manifold split also install the harness before putting the top of the manifold back on.
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
HRDC0R19
Jul 5, 2015 06:43 PM
