How far can the 3.0 go?
Old Dec 31, 2010 | 06:45 PM
  #221
smarvin's Avatar
Super late on this one but i just saw it.
192,000 the past owner beat the crap out of it in the sandy mud of Florida and now I am beating it up in the Lava. When i first bought it at 178,000 i had to do new rear end and a trans.. and right now it's in there getting a HG job water pump,timing belt, radiator and a knock sensor. Thing should be like new when i get it back! Or it's going into the ocean
Old Mar 31, 2011 | 12:49 PM
  #222
Psyche's Avatar
I got 313,000 out of mine. It's dead now though, I'm replacing it right now.
Old Mar 31, 2011 | 01:24 PM
  #223
94toyota's Avatar
i got 138,111 original headgasket on my 94 and its still going strong glad to see not every one hates there 3vze's
Old Mar 31, 2011 | 09:09 PM
  #224
offset442's Avatar
198,983 miles 1988 4x4 badly abused picked up for 500 bux at a tow yard under salvage title leaking coolant.
since have replaced the u turn hose of the back of the motor that was leaking the coolant, the water pump, O2 sensor and repaired burned ecu. sealed the cold start bypass air intake valve to fix high idle(what a funky design like a thermostat)
have variously minor oil leaks that are highly annoying, and one weak cylinder that needs a valve repair showing 120psi hot compression. also likely could need a use a round of new crank bearings, because its a manual I sure that the thrust bearings are wasted if not read to fail.
I think 200,000 if a good time to to a general red neck quick rebuild
-valve job for both heads
-new crank and rod bearings and thrust plates
-rings pistons bore, and hone???? optional maybe
-oil pump, it probably looks ok, but that shaft is getting fatigued, might snap off before the motors time
-SEALS
-SEALS
-SEALS
-gaskets NO SILCONE!!!!! USE SOMETHING BETTER hylomar, hytac, aviation forma gasket etc
-NEW Coolent hoses
Old Mar 31, 2011 | 10:32 PM
  #225
brandon16's Avatar
mine has 160,000 hg done a while before i bought it and runs strong, leaks oil from valve cover, my brother has 270,00 rebuilt by po. loud valves but runs strong
Old Apr 1, 2011 | 12:46 PM
  #226
shaunneuhaus95's Avatar
i got a 92 runner with 242k and a 94 runner with 172 k
Old Apr 1, 2011 | 01:20 PM
  #227
Swimmerboy2112's Avatar
My 1995 4Runner blew its gasket at 258K
Old Apr 2, 2011 | 05:48 PM
  #228
StroupDog's Avatar
Just turned 252k today, original head gaskets. We'll see how long she lasts. No noises or oil burn but a little low on power. Got 14mpg last fill-up mixed driving.
Old Apr 2, 2011 | 06:01 PM
  #229
KFP's Avatar
KFP
88 pickup got 290000km out of 3.0
Old Oct 5, 2011 | 12:14 PM
  #230
rebs4x4's Avatar
89 4runner 213000 miles on the 3.0L still runs good just bought it so i dont have any service records but looks like the OM motor. Has good power but the clutch in slipping a bit it has a few oil leaks when i pull the trany to replaced the clutch i will replaced rear main and valve cover gasket that should take care of the leaks.
Old Oct 5, 2011 | 01:56 PM
  #231
YFZsandrider's Avatar
My '93 pickup just clocked over 260k miles. It had a head gasket recall performed in '98 by a previous owner, no extensive work done since, as far as I can tell.
We'll see...
Old Oct 5, 2011 | 02:12 PM
  #232
MaK92-4RnR's Avatar
my truck blew headgaskets at 150k even with headers... ticking time bomb, and could go off at any minute. Headers do not help.
Old Oct 5, 2011 | 02:34 PM
  #233
crash454ss's Avatar
320 000 hard worked km then timing belt idler pulley let go, the engine ran really low because of an oil filter gasket and started to have a bottom end knock then the headgasket started to go all in a under 1000km
Old Oct 5, 2011 | 04:20 PM
  #234
fjosh's Avatar
322,xxx and I will be driving it to work tomorrow.
Old Oct 11, 2011 | 01:54 AM
  #235
Turtle Runner's Avatar
Mine has 340,000 on it now. About to do intake/afm mods. Have done headers and exhaust already
Old Oct 11, 2011 | 03:03 AM
  #236
TNRabbit's Avatar
Bought mine in 2000 with 93,000 miles on the clock. Had just had dealer HG recall done before I bought it. I ran it up to 218,000 miles in 2007 & blew a HG after overheating it twice (leaking water pump). Did a full rebuild & now have 264,000 trouble-free miles. I've replaced the TPS, Fuel Pressure Regulator, Fuel Pulsation Damper, Fuel Pump, Fuel Filter & Distributor in the past year. Runs GREAT! I'm averaging over 17 mpg city/highway right now.
Old Jul 8, 2012 | 11:35 PM
  #237
Marc A's Avatar
Mine is a 93 3L 5spd and i have 349K head gaskets done almost 200K ago and before anyone calls me out on this i have prove it....
Old Jul 9, 2012 | 08:40 AM
  #238
amusement's Avatar
Talking
Don't doubt it with reasonable maintenance and care. My Ford Ranger is jealous and decided to shut off it's air-conditioning today.
Old Jul 28, 2012 | 08:07 AM
  #239
NorthIdahoyota's Avatar
279K with only basic maintenence and lots of time at the redline. Burns oil, has little power and only gets 16mpg on the highway but cannot kill it.
Old Jul 28, 2012 | 09:29 AM
  #240
Resto-noob's Avatar
Just brought mine home two days ago-my first 3.0-and it has 256,xxx on there. No idea as to what it's had done to it, but compression checked out. I did buy the whole truck just to get the doors and part out the rest though.
