Hiding the gas tank on 89 runner
Old Dec 14, 2008 | 12:21 AM
Matt16's Avatar
Originally Posted by leebee
lifting the gas tank on a 2nd gen is possible, 2" b/l allows you to r & r the tank to the top of its current location. there are several links to installing long range tanks where the spare is located. search is your friend.
lee
I'm afraid it isn't possible to lift the gas tank on a 2nd gen 4Runner. The coil spring suspension takes up a lot of room. Specifically the passenger rear upper control arm prevents the tank from being mounted any higher BL or no BL. You'd have to clearance the tank.
Old Dec 14, 2008 | 03:18 AM
jacruz2's Avatar
Well he shouldn't have to worry about links on a first gen runner. So here is a link to a killer 2nd gen runner on leaves all around that should give you an idea. I think he said he raised the about 3" or so.
http://www.pirate4x4.com/forum/showthread.php?t=220153
Old Dec 14, 2008 | 05:10 AM
4runnerx3's Avatar
This 4runner that was on ebay a while back had a smaller tank.
Old Dec 14, 2008 | 10:43 AM
leebee's Avatar
matt
your last sentence seems to contradict your first:
lee
Old Dec 14, 2008 | 10:53 AM
  #25
BoostedRNR's Avatar
For you guys with 2nd gen, search fillsrunner4 build. Very good idea just looks like a lot of work.
Old Dec 14, 2008 | 01:36 PM
  #26
Matt16's Avatar
matt
lee
You're right, if you think it is wise to take an angle grinder to a gas tank.
Old Dec 14, 2008 | 01:47 PM
  #27
Tofer's Avatar
Sponsor
Originally Posted by anthony1
you must make sure you don't pinch the nipples
i for sure dont like my nipples pinched....
Old Mar 24, 2009 | 11:19 AM
  #28
94sasyota's Avatar
hey i wounder how hard it would be to put a fuel cell in the trunk and what would be needed to do the job right fuel cell,fuel pump and lines what else would be needed
Old Mar 24, 2009 | 11:37 AM
  #29
Junkers88's Avatar
In the trunk of a what?
About halfway down this page is the fuel tnak I'm putting in my 89 4runner so I can remove the factory one. I'll let ya'll read it.
http://www.downeyoff-road.com/BodyCo...iaryTanks.html
Old Mar 25, 2009 | 03:08 PM
  #30
AxleIke's Avatar
I just moved mine:
It tucks up nicely, just depends on how much sawzall you are comfortable with:
Old Mar 25, 2009 | 04:37 PM
  #31
Junkers88's Avatar
Originally Posted by AxleIke
I just moved mine:
You have to post up a detailed thread, really. I'd much rather do something like this than spend 500$ on the tank I'm looking at. That money can go a long way towards other mods.
Old Mar 25, 2009 | 05:38 PM
  #32
AxleIke's Avatar
No need. No detail to it. Just cut out the old xmember, weld in a new one, cut a hole, weld mounts for the tank:
Then just hook up the lines.
Old Mar 25, 2009 | 08:26 PM
  #33
Dbl. E's Avatar
Ike, did you use Ford I-beams for rear trailing arms? If so, I like the junkyard engineering.
sorry for the thread jack
Old Mar 26, 2009 | 05:01 AM
  #34
AxleIke's Avatar
No. No domestic stuff in this truck. 100% toyota. Those are FJ80 radius arms. Better clearance than leaf springs and no axle wrap.
Old Mar 26, 2009 | 05:19 PM
  #35
Dbl. E's Avatar
Sweet, you going to leave IFS?
Old Mar 26, 2009 | 06:50 PM
  #36
AxleIke's Avatar
For now. I haven't gotten to any trails where the IFS was holding me back. I enjoy the need to actually have skill to drive a trail, rather than point and shoot.
Eventually, there will be an FJ80 HP front axle in there, that is currently collecting dust in my garage.
Old Mar 26, 2009 | 06:59 PM
  #37
Dbl. E's Avatar
Get that thing finished and on the trail. I want to see where the added rear articulation will take you.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
